altie
Man, I should've known these DIY ES phones would be the never ending project. Going from the plans on Headwize my pops and I built a pair of ESL drivers and got to work on the simple receiver-driven step-up amplifier. That should be the easy part, right? Not so much.
I've tried two sets of 20v-70v transformers. Both are enough of a step up to generate quite a bit of sound out of the drivers, but with extreme distortion. There's lots of crackling, weird harmonics and such to the point where vocals and some instruments are unintelligible. Is this amp really only intended as a quick test for the drivers? Note, I haven't hooked up exactly the step up he indicated. The highest step up my transformers will support is 8ohm-1K. I wouldn't think the higher current on the output side would be the source of the distortion with the receiver turned low, but it's still there. Any ideas? If my drivers put out sound at all, is it worth it to build a real amp? Please keep in mind that I'll sink plenty of time into this, but money I'm more attached to.
