Originally posted by Joe Bloggs
Well, what does the difference sound like?
Technically, all I know is that as you go down classes low level information is represented less and less well right?
So basically it tends to wash out detail, is that it?
Part of it is low level information, but a bigger part is speed and "verve". A class A amp sounds more smooth and dynamic. Also, from an engineering standpoint, there tends to be more distortion in lower classes. This distortion tends to have odd harmonic content, which is unpleasing to the ear. (In contrast, a Stradivarius violin tends to have a lot of even harmonic content.)
Hmm, if I'm reading your post above right, you mean that apart from damping factor (which affects the control of bass rather than the amount), there's no compromise decisions in the amplifier proper that would specifically affect bass response? I suppose you'd just not listed it out
No, there's much more than just damping factor to consider. That was just an example.
I know the input caps (if you have them) can roll off the bass, but that's about it
Here you're referring to the input coupling caps, not the power supply caps. These aren't really an issue. As long as they're big enough they won't filter out the bass, but this is a separate issue from how much bass the amplifier can produce.
In general, an amplifier may have capacitors in four places:
1) the power supply
2) input coupling
3) output coupling
4) elsewhere for stability.
Only 1) is truly necessary, the rest are optional, especially 3) and 4). As you move to higher end designs, the optional ones dissapear. For instance, the Gilmore amp uses a servo instead of 3). The Meta42 avoids 3) also. The perceived amount of bass output by the amp is primarily affected by 1).
What I'm trying to figure out is, why people keep on saying that more high end amplifiers have better bass. Is it just because of the power supply or...
And it seems some of the factors affecting bass response have nothing to do with how much power the amp is designed to give and how much it's being asked to give... |
It's not only just because of the power supply, but the power supply is a big part of it. Visit a store and listen to some high end amps driving speakers with large woofers and you'll see that there are often dramatic differences in bass response. You're absolutely right on the second point, of course, the output power rating of the amp (e.g. 30wpc) has virtually nothing to do with the amount of bass it puts out. There are crappy Sony subwoofers rated at 100wpc that have absolutely flabby bass. I used to own one before I knew any better.
