SparkOnShore
- Oct 26, 2014
Like I said, ignorance is bliss!
I agree. Audiophoolishness as well!! Best wishes!
Thanks for the note. I know about that clipping (I read Archimago too)). Yes, it was ruled out during recording of SE test sequences. The sound signature (artifact signature indeed) of iPod 5th is due to Wolfson chip architecture. Mid frequencies degrade to more extent than highs. Odd harmonics prevail in the distortion.
I needed a device which could be plugged into the cigarette lighter to keep the iPhone charged, as well as a DAC function.couldn't you just use the lightning headphone adapter dongle?
[1] Done it already, and difference is night and day. Have you? [1a] or don't and save a bunch of money. Ignorance is bliss.
[2] Also, you have to have the gear to hear the difference.
Agreed on this front. Every piece of gear has a bit of color. Even the supposed absolutely neutral stuff. This is what makes the great gear stand out.
Conclusion: thanks to Wolfson audio chip with relatively high level of waveform degradation iPod 5th (Video) has its own distinctive sound signature (slightly harsh mids, transparent highs).
You might want to double check that with a quick listening test. Because I've done careful listening tests with all of my iPods, iPhones and Macintosh computers, including ones with Wolfson chips and going all the way back to the 8500AV, and they all sound identical. Something else might be causing the distortion you measured, or perhaps it is a form of distortion that isn't audible.
Some more thoughts on those old iPods, now that you've ruled out the clipping issue:
I'll have to dig up my old scratched up iPod to see if the hard drive still fires up, lol.
- It looks like you're testing with a 32-ohm dummy load on each channel, at 150mVrms. From what I can remember, the performance of the 3.5mm output gets a lot worse with a low-impedance load like that. The distortion figures are much higher, for example. But that's really the built-in headphone amp's fault, not the DAC's. Newer iPhone and iPad headphone amps are a lot better here.
- If the testing chain really looks like it does from your picture, then you're really testing DAC -> Headphone amp -> output R + blocking cap (even though the R+C really should be part of the amp itself). At a 32-ohm load, you're going to see (and hear) the effect of that capacitor on the frequency response. It's quite noticeable, much more so than the differences between DACS.
- If you really want to characterize the performance of the DAC, take the line output from the 30-pin connector. Of course you'll have to do away with the 32-ohm dummy load. Or, if you dial back the volume so that it's at unity gain instead of overdriving the headphone amp, you can hook up the 3.5mm jack to a typical line in (10 k+). The performance should be a lot better because you're not seeing the effect of the headphone amp being asked to drive a difficult load.
- I also noticed that even with a high impedance load, the noise and distortion go way up when the iPod is charging via the 30-pin connector. The distortion was up by a factor of 10, IIRC.
- Again, what's really noticeable in real-world use, much more than the DAC's performance itself, is the headphone amp. Its self noise isn't as good as the newer Lightning or USB-C dongles. You can really notice it on ultra sensitive IEMs. The bass roll-off from the blocking cap is also very noticeable on low impedance loads.
From what I can tell you didn't test the Wolfson chip, you tested the combination of Wolfson chip + amplifier and therefore you have no basis for your conclusion because it could be entirely "thanks to" the amplifier and have absolutely nothing to do with the chip. And, as already mentioned by others, it could be entirely thanks to the amplifier ONLY when under an inappropriate (not designed for) load. Do you have any objective evidence to support your conclusion?
G
I have some doubts that quick listening test will be appropriate for the case. At least I will need high impedance and high sensitivity headphones. Not to say about providing true blindness of the test, which is not easy indeed.
You can't depend solely on measurements and try to relate that to audibility in the abstract. You have to use real human ears. People in hifi forums who don white coat and pretend to be scientists tend to fall prey to doubling down on "what ifs" and "just to be safes". They end up thinking that things that are completely inaudible in the real world might just possibly be audible if the circumstances are right. They're correct of course, but who lives in an anechoic chamber? I sure don't! I just want to know if something is audibly transparent in the way that I use it... listening to music in my living room. It isn't hard at all to set up a test to determine that.
In music-based audio metric such relationship between measurements and audibility can be researched and used in practice. In traditional audio metric this relationship can be traced only by audio professionals with experience. For consumers the interpretation of traditional measurements is made mostly by marketers.
I'm sure that both approaches objective and subjective are valuable for assessment of perceived sound quality. We just need to find the right combination of them.
To have some "safe margins" is quite reasonable due to complex nature of human perception of sound and its quality and due to our not complete knowledge of the issue. Also we don't need to be 100% efficient while manufacturing and choosing the right audio equipment. Some extra quality is psychologically comfortable when we talk about Music and shows some respect to audiophiles. In the end audiophiles do not try to sell you usual audio equipment as premium one, manufacturers do.
Good question. To be honest there is not enough info about correlation between measurable degradation of waveform (Df, dB) and audibility of that degradation. Such info can be derived from results of various listening tests. I have only preliminary figures based on analysis of HydrogenAudio listening tests of codecs and beta-testing of 30+ portable players on SE site. At this point of research I'm pretty sure that 10dB improvement in reproduction of real musical signal is huge and must be audible. 10dB is the difference in measurements between early portable players like iriver E100, iphone 3G and modern top smartphones by Apple, Huawei and Xiaomi or iPod classic 2009 for example. Then, looking at df-slide with measurements of iPod 5th we can see that 1kHs Sine is degraded higher than 12.5kHz Sine (more harmonics) and odd harmonics are prevail over even ones (relative position of two triangle signals which is also confirmed by traditional spectral view of harmonic products). So it's quite easy to say how exactly that degradation will be audible - harsh mids. But in general I agree with your objection - relation of df-measurements and audibility should be researched better. I wish I had more time for this but I do what I can.You made claims of an audible difference in equipment without doing any reliable listening to back it up, or evidence or data that the difference, however much it might approach the audible, would actually be audible to you or anyone. I really like a lot of your work but for me that is going one step too far. It takes us down the rabbit hole.
As a for example, I looked up @Voxata ‘s equipment he listed in his last post. It had been carefully measured on another forum I find credible. Apparently it all measures extremely well for its price point. He seems to have chosen carefully. If having something that measures really well for the price point gives you pride in ownership and it doesn’t break your budget at all I’m all for it. It’s not my cup of tea but I get it. But as the reviews made clear all characteristics that were measured and were not quite as good as the very best measurements they had ever encountered or were otherwise remarkable were far lower than the known thresholds of audibility.
Now, will this iPod you discuss sound exactly the same? If by measurements it’s an edge case I think it would be best to say we don’t know, rather than to speculate based on certain aspects of the measurements that it would be audibly non-transparent for its intended purpose and further speculate as to the purported minor non-transparent characteristics of the sound that would result. That’s why I think you went one step too far there, from someone with absolutely no dog in this fight.
I think my reply to Steve999 also suits your objections. I will just add that I'm trying to use results of third party listening tests for the research, not mine. The reason is clear I think.Most of the published studies on thresholds of audibility are done with tones, not music. In practice the thresholds are as much as an order of magnitude lower when you are using music than with tones. (PS I'm a professional with experience.)
You should just do some simple listening tests yourself. I know in audiophile forums people attribute all kinds of coloration to DACs, But I've done controlled listening tests of various DACs (Wolfson, Cirrus, Sabre, etc.) All the ones I've tested are audibly transperent. If you took the time to do some tests yourself, you would know this too.
