what is sound card volume (loudness) refer to
Feb 26, 2013 at 3:26 PM Post #3 of 5
musicana
The higher the output impedance (rating in Ohms), the louder it'll go. An 80 Ohm output is made to drive 80 Ohm headphones, so it'll be louder than one that outputs, say, 25 Ohms.
http://www.creative.com/corporate/pressroom/releases/welcome.asp?pid=13137
Headphone output for audio listening up to 115dB 33 Ohms, and 117dB, 330 Ohms, at 24bit/96kHz
why it have two output impedance
Feb 26, 2013 at 3:33 PM Post #4 of 5
chewy4
Soundcard specs don't really give you enough info to determine how loud it is. They generally say nothing about voltage, wattage, and ouput impedance, and disregard the fact that headphone's have different sensitivity.
What you are looking at is the input impedance of the headphone's that it claims it can power, not the output impedance of the sound card. The output impedance of the Titanium HD is about 35 ohms.
The thing BetaWolf said is just plain wrong though. You generally want something with a low output impedance(many say 1/8 of your headphone's input impedance) and then judge it by voltage or wattage. Which both vary based on the headphone's input impedance I believe.
Feb 26, 2013 at 6:38 PM Post #5 of 5
mich41
That's very simple, actually :)
A soundcard analog output is approximately a voltage source, a resistor and (sometimes) a capacitor in series.
If the capacitor is too small, it will reduce bass. If it's big enough (or not present at all) it can be ignored. We will ignore it from now.
The voltage source is limited to some voltage, say V. It's power supply may be limited to some current I and/or power P.
The resistor has some resistance called Zout (output impedance, but it's basically pure resistance).
Every headphone has some impedance, say Z. The exact impedance is frequency-dependent and in some/many cans it's higher around 100Hz (see here for examples).
By Ohm's law, the output will produce V/(Zout+Z) of current, yielding V²/(Zout+Z) power. Since headphone and output impedance form a voltage divider, headphone will receive Z/(Zout+Z) of this power, i.e. Z*V²/(Zout+Z)².
From this and the "SPL at 1mW of input" spec you can derive approximate loudness.
Practical things to note:
- low Zout is desired because it minimizes Z-dependent variations in headphone power
- IEMs have large Z-variations across audible frequency range and hence sound bad from high Zout outputs
- power used by the headphone is maximized when Z equals Zout, not when Z is as low as possible - a common misconception here
- current,power produced cannot exceed I,P or clipping will occur, not some mysterious "not enough juice" - another misconception
- forget about getting these specs from soundcard manufacturers, except for pro gear
- you can find instructions on measuring most of this stuff using a multimeter and few audio cables
