What is a Solid Tube, and other questions
Mar 19, 2006 at 3:49 AM Thread Starter Post #1 of 4
raduray
I've read reference to Solid Tube in the Xin amps, but I can't find out what that means. Anyone know?
I tried doing a search on "Solid Tube" with quotes around the string, but most of the many returns did not match the string. The had "Solid" and "Tube" in the posts, but not "Solid Tube"
Finally, is there a site that lists and discusses the attributes of the various op-amps used in amplifiers?
Mar 19, 2006 at 4:37 AM Post #2 of 4
Demolition
Xin's Solid Tube is an opamp that has a distortion level similar to a vacuum tube. The end result is that you get a more tube-like sound from your amp.
See this article at Tangent's site.
Mar 20, 2006 at 3:32 AM Post #3 of 4
redrich2000
The Solid Tube is also known as the AD8656. I just put mine into my supermini yesterday. I can't say there's a massive difference, but then I'm not as discerning an audiophile as some here. The stock op amp in the supermini is meant to be "tubey" as well.
For info about op amps, do some searches in this forum.
