SanjiWatsuki
- Oct 21, 2011
Probably that not as much as you may think as we hear in a logarithmic fashion. The cable would have to be 32 Ohms to make a -6 db loss, a 5 Ohm cable resistance would result in a -1.26 dB loss and a 1 Ohm cable resistance in a -.27 db loss. See the below equation.
20 * log(32 /( CableResistance + 32))
My point is just that I doubt that 1 ohms is the highest measuring resistance in a cable ever. Although in most cases there would be a likely inaudible FR shift as a result of using a different cable, I believe that there are likely a select few cables which will result in differences.
