What does a buffer do for the output stage of an audio amplifier?
Jan 30, 2012 at 10:39 PM Thread Starter Post #1 of 6
FloydCouncil
I have been studying the various schematics of op-amp based audio amplifiers and I notice almost all of them include a buffer stage. Why is this so? Wikipedia states a buffer will provide a very high input impedance to the output of the op-amp and a low output impedance. How does this benefit the sound of the amplifier? As I understand it will probably allow headphones of different impedances to be used.
Secondly, is there a significant different between using a integrated buffer or a discrete one? I am considering designing an audio amplifier for my HD650 - nothing fancy, just based on OPA637. I'm an electronic engineer but I'm mostly experienced in embedded electronics than analogue.
Jan 30, 2012 at 11:11 PM Post #2 of 6
An op amp is like a gain adjustable buffer but has limited current capability. A buffer circuit provides more current. Often needed with harder to drive head phones or dealing with certain op amps. To go discrete or not depends on the engineering and component selection. I prefer a proven chip design because you take a number of variables out of the equation. If you can hand pick matched transistors and killer capacitors then discrete could sound better.
Jan 31, 2012 at 12:25 AM Post #3 of 6
A buffer isolates the gain stage from the relatively low-impedance of the load. Think of one stage to provide voltage gain and one to provide current gain.
Jan 31, 2012 at 1:39 AM Post #4 of 6
http://gilmore2.chem.northwestern.edu/library.htm could keep you in reading material for a while
I cite this one a lot http://gilmore2.chem.northwestern.edu/articles/hearing_art.htm - read twice - for protecting yourself and then for Dynamic Peak SPL estimates - which lets you size a amp for a given headphone's impedance, sensitivity
for the HD-650 getting to 120 dB SPL peak requires ~ 12 Vpk, 40 mApk - this is a pretty high amount of dynamic headroom you may never have a clipping event depending on music genre and whether you really ever try to literally reproduce live event SPL peaks
yet with a op amp + buffer it is a pretty easy goal to meet for the HD-650
another overkill approach common in headphone amps is to run the output in Class A bias - avoids a few error mechanisms and at headphone power levels it doesn't cost too much for desktop amps
the current and power to do this with the HD650 are within the limits of some op amps but the easiest way is to use a separate buffer amp giving greater freedom for choosing the input op amp
I strongly advocate putting the buffer inside the op amp Global feedback loop - Walt Jung has articles, explanations, check out his Op Amp Applications book (free online) - particularly the audio line diver circuits - section 6 http://www.analog.com/library/analogDialogue/archives/39-05/op_amp_applications_handbook.html
like Jung I prefer current feedback op amps for the output "buffer" - the TPA6120 gives an impressive spec as a headphone amp on its own - but I still wrapped a OPA627 around it in my amp (avatar)
Feb 4, 2012 at 3:28 AM Post #5 of 6
This isn't really related, but what is the giant heatsink for? Did you bias your TPA6120 into class A?
-Kris
Feb 4, 2012 at 2:47 PM Post #6 of 6
yes I did, it is possible to bias parallel op amp outputs "against each other" for push-pull Class A, simple sim examples next page:
http://www.head-fi.org/t/188758/ad8397-class-a#post_2263321
you could do similar with parallel buffer chips
really inefficient is to load the ouput stage to a rail in SE Class A output
