esldude
- Dec 8, 2001
I am assuming that you are talking about this track? http://www.youtube.com/watch?v=IUDTlvagjJA
I dunno. For the test track above, I can distinctly hear the exact spot where the sound is coming from with both my open HE-560s and closed M50x, so sound stage definitely exists if present in the recording. I never personally experienced the sound moving or flickering in locations in a weird way. The sound moves closer & farther away & around my head very precisely and linearly for me. I do not think the idea that there are different cues in sound intensity & arrival time contained within the source that creates the perception of sound stage is a "trick." It really is just how our brains process and interprets distance cues. When you listen to movies or game with headphones, you can often get the positional cues from the sound. I have also noted a perception of distance and sound stage in non-binaural recordings where you can hear exactly where an instrument is in space not located in the 'center of your head'. With live orchestral pieces or vocal performances, I feel like I can accurately place where the instruments are in space.
I am unable to accurately tell whether there is a large differences in sound stage are between these two headphones because I am unable to do an exact volume matching or blind test as they feel very different on your headphone. However, both headphones present the illusion of space very effectively.
I am curious if you hear the center vs twisted the same or opposite with your headphones and if you can hear the distance of the knock in the binaural test track located here: http://www.audiocheck.net/soundtests_headphones.php
Yes the youtube track is the one I had in mind. The door knocking works quite well. In the barber shop track, it works fairly well only when directly right or left. Like the door knocking. Move the slightest bit from full right or left and it jumps inside my head. The scissors sound just outside at times and jump inside most of the time. Quite yucky sounding in that regard. Same with the electric razor.
