KellDammit
- Jun 13, 2003
anytime
i'm a pc user, and my laptop firewire doesn't supply power, so i can tell you that just sending a fair amount of material (a couple gigs) to the ipod would kill the battery very quickly.
apparently the new ipods don't have quite the battery life that the older ones did. i believe the 160k/4 min songs at around 50% volume (i'm assuming no eq, etc) are supposed to get you around 8 hours of battery, according to apple. i've heard higher and lower...so ymmv.
another couple tips...
1. try to keep your backlight useage minimal.
2. try to keep the volume at or below 50%.
3. don't use eq, shuffle, etc...basically anything it has to think about other than playback will cause more drain.
4. don't skip around a lot (causes disk spinnage/rebuffering).
at 192k, i'm still showing 4 "bars" of battery after 2-3 hours of continuous use, so i'm happy. i havn't really had much more time than that in one stretch to see how long the battery will actually hold out.
enjoy!
kell
enjoy!
kell
