WalkGood
- Oct 5, 2007
Flat is best on OF although rockbox is a different story, crossfeed, stereo width and a little extra bass ftw
Originally Posted by bixby /img/forum/go_quote.gif How can you take the midrange down to plus 2? Besides the clip loses about 3db or more of volume when you go into custom EQ mode. Yet to each their own. I have used the clip with the PK3s and see no reason to use the eq. Then again , I feel all EQ on these devices are crap and never use them. My theory is that if you have to use EQ you have a serious problem somewhere in the listening chain. After re-reading your post, I think someone jacked up all your eq settings if you are pulling them down to numbers such as plus two or four and I think you are referring to clicks above the center line right? Not above the max cut line way down at the bottom. |
Originally Posted by bixby /img/forum/go_quote.gif Sorry, but I don't follow uselander logic. Where did you come up with using normal EQ as being eq at Plus 4. I have attached a simple chart that show what Plus 4 might look like. The horizontal line is FLAT, no EQ. Putting an equalizer up plus 4 on each of the pivot frequencies would do something like in the chart. If you feel flat is the bottom of the graph, you are in error. It is actually the inverse of my crude drawing, with deep cuts from flat. I can see how one might interpret this if you are not familiar with Equalization. And FWIW, I count 12 discrete clicks form the bottom of the EQ range to flat and 12 more from flat or the center line to the max eq for each. So I am still at a loss to see how you get 4 clicks down from some "normal" setting to equal flat. Are we talking about the Sansa Clip?? |
Originally Posted by bixby /img/forum/go_quote.gif I'll have to give that a listen, but if Sandisk is doing that they are whacked, no wonder people are all goofey over EQ with companies doing stuff that makes absolutely no sense. I'll give it a listen and then comment, but I see your point. |
Originally Posted by bixby /img/forum/go_quote.gif You have made a very important discovery. From my brief listen a few moments ago, I have to agree with your hypothesis. Plus 4 on all pivots sounds remarkably like normal. Now if that is so, it is kind of like the Plasma tv manufacturers who run their settings on 95% bright and picture because it looks more impressive. Then when you get a real reference to cinema you drop those levels down to 60% or so. This is totally whacked! My apologies and I will look into it further with some pink noise to see how that sounds. What is fairly obvious is that plus 4 sounds nowhere near what a real equalizer might sound like with only 5 pivot points for the entire spectrum. |
Originally Posted by bixby /img/forum/go_quote.gif I have listened briefly to pink and white noise files on the clip and only figured out a few things. And these are only to my ears, thanks to the alertness of uselander. 1. Custom EQ set at plus 4 clicks at all frequency pivots seems to equal the normal setting in tone and volume 2. Custom EQ set at minus 4 clicks seems to alter tone from the normal setting when you compensate for the lower volume level. 3. Custom EQ set at flat for all freq pivots with the highest at plus 1 plays much lower in volume than normal but when increased in volume to compensate sounds like normal with a very slight bump up in the upper highs. 4. Custom EQ set at the zero line equals the normal setting in tone and volume 5. I can't spend any more time fiddling with EQ! Conclusion- EQ designers are playing with their audience. It truly is a whacked phenomenon and is not to be used. Hence my distrust and distaste for all DAP EQ. All kidding aside this is weird. |
Originally Posted by Peyotero /img/forum/go_quote.gif Some one should compare rockboxed vs original. ... ... |
Originally Posted by WalkGood /img/forum/go_quote.gif Rockbox is not ready for prime time use, I am running it and it will sound fine at times for a whole album but then all of a sudden a glitch will sound, so it's still glitchy and hasn't been released, you can read up on it here. |
