davidd
- Sep 16, 2004
Today I decided to start experimenting with AAC, so I took 145 of my FLAC's and used foobar2000 (with the Nero AAC encoder) to convert them to AAC. I used the default MP4 extension for these.
Then I added the songs to iTunes' library, but only 144 were added. So after finding which song it was, I tried to add it by itself and it still wouldn't go.
I then thought that maybe it was a bad source file, so I re-ripped the disc to FLAC with EAC, and converted the songs to AAC with foobar again. same problem with the same song not wanting to be added.
After being frustrated for a while, I decided to ripped the song to AAC with the M4A extension instead, and iTunes added that fine.
So for some reason iTunes is happy with 144 songs having an MP4 extension, just not this one for some reason, which is puzzling me, so I was wondering if anyone else has had this issue ever and how did you fix it. I know I could just use the M4A extension for all my AAC's, but I'd much rather use MP4 since that's what the AAC specification says to use.
(the particular song is Dream Theater's The Rover / Achilles Last Stand / The Song Remains the Same medley from the A Change of Seasons EP if that matters any)
