Weird PPA problem
- Thread starter hypophysis
dviswa
- Mar 30, 2002
- Messages
- 170
- Reaction score
- 10
Have you considered replacing the sockets the buffers are on? Somehow I get a feeling this is a dry solder or loose/bad contact situation. Or maybe just reheat the solder points with some flux so that dry joints maybe eliminated.
hypophysis
- Apr 24, 2004
- Messages
- 41
- Reaction score
- 0
But I don't think a loose contact on the buffers can prevent the whole amp from powering up. Soldering on the amp is perfect, it's been done by doobooloo.
Originally Posted by dviswa Have you considered replacing the sockets the buffers are on? Somehow I get a feeling this is a dry solder or loose/bad contact situation. Or maybe just reheat the solder points with some flux so that dry joints maybe eliminated. |
@sia@home
- Oct 31, 2004
- Messages
- 133
- Reaction score
- 10
how big is your rail?
Mine is 5440uF, but I haven't powered it on yet, due to still missing some vital parts.
tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
- Messages
- 5,969
- Reaction score
- 56
- Sep 27, 2001
It's possible that the power supply is having a hard time during the turn-on time. Often a regulator will stay near 0V (2-3V at most, not enough to turn the LED on, or allow it to be bright if it is on a little bit) if it's having a hard time getting started. Too much rail capacitance is one way this can happen.
Also possible is that the buffers or the op-amps are licked up at one rail for some reason, and touching the meter probes to the rails "unlocked" them.
When you get it into this condition again, measure from V+ to V- again, at the DC input jack. If the amp doesn't come up, the value here might be educational. If this always brings the amp up, let us know that, too. It might help us understand what's going wrong.
And no, the lack of a power supply diode will not cause this problem.
