Website Design Help
post-203529
Thread Starter
Post #1 of 7
NotoriousBIG_PJ
Step 1: Plug power cable into wall. Step 2: Plug other end of power cable into....umm.... Step 0.5: Order something to power with power cable.
What is the best program for image editing for websites? I am using Dreamweaver for websites right now.
Thanks,
Biggie.
post-203538
Post #2 of 7
royboy2k
Do you mean like photo editing (Photoshop)? Or do you wanna create buttons and stuff? If so you could check out Fireworks, which is designed to complement Dreamweaver.
post-203580
Post #3 of 7
NotoriousBIG_PJ
Yes, I'm interested in making some cool buttons. :p
Biggie.
post-203590
Post #4 of 7
CaptBubba
Not dumb enough fora custom title...so he thought.
yeah, fireworks is pretty sweet because you don't even have to exit out of dreamweaver to edit stuff.
post-203698
Post #5 of 7
LobsterSan
MOT: kuboTEN
Just so you know, there are two types of graphics editing programs out there. The first is sprite-based editing, such as Adobe Photoshop. This is good if you are working with things such as photographs or highly detailed images. The other type of graphic editing application is vector-based, such as Adobe Illustrator or Macromedia Fireworks. By using vectors, you are able to scale images without any loss in quality. Vector-based programs are good for creating things like buttons and stuff that you would need on a website.
Fireworks would be a good bet for you, since you are using Dreamweaver.
If you also need to do some sprite editing, Photoshop is just about the best (and most widely used) out there.
post-203741
Post #6 of 7
kin3tix
flash is so awesome. u can make some really cool buttons there if you wanna do that too
. pretty sure you've been to some sites made entirely of flash and shows what it's capable of. check that out also.
post-203786
Post #7 of 7
NotoriousBIG_PJ
Thanks for the help guys.
Biggie.
