bhobba
- Jan 4, 2008
Hi Guys and Rob
Just ordered both the TT2 and M Scaler. My normal dealer didn't handle Chord so I went to an old acquaintance that runs a Hi Fi store and yes he could get it in so ordered it. But my dealer is building me a really high end pair of speakers I head for the first time in close to final form. OMG is all I have to say. But he pointed out it will be best with a special stand he is designing and as my finances are not unlimited had to cancel the Chord. But very fortuitously my normal dealer found a way he could be a Chord dealer and is getting one in so It will be happening. In fact after reading about it, he will be designing some speakers specially for it using the Seas Exotic Drivers. This raises a few questions I was wondering if Rob could answer
1 The cables my dealer uses is ones he makes that have a slightly higher capacitance than normal. It usually isn't an issue but my Grandinote Amp has trouble so I use other cables for that amp. Any issues with the output of the TT2?
2. The designer of the speakers usually lines them with steel, sometimes the more expensive option of copper. He electrically joins them together to form like a Faraday cage. Claims there is a small, but noticeable improvement. Would there be any harm in checking if connecting that 'cage' to the earth on the XLR output makes a difference
3. Can the normal rca plugs at the back be simultaneously connect to an active sub-woofer. I am pretty sure it can but just wanted to check.
In the interim he will be building a special cable to see how it sounds with the most sensitive speakers he currently makes at 89db which should work OK.
Will be very interesting to see how it goes against the other DAC's I have available like the Grandinote.
Thanks
Bill
Thanks
Bill
