Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
I wish. Davina project has been on the back burner a bit. The decimation filters (768>48 kHz) is done and tested and work perfectly. I am currently doing the 104.25MHz > 768/705.6. This has proved mighty tricky, as the decimation is 135.75; the tricky part has been arranging a filter to do non integer decimation, without the possibility of any added THD and noise, nor aliasing; but I have managed to do this, at least at the top level design. I set myself the target of zero aliasing from 104 MHz; it's actually better than 250 dB from 384 kHz to 104 MHz, and uniquely is a linear phase FIR filter not the usual cheap and nasty moving average decimation filter. Should have this finished when I get back. Then it's coding for the pulse array, then hardware testing will start. I have set myself the target of actual recordings for next year, as the project has been swamped due to work commitments.
