At least people aren't too specific about their wants
I'd settle for an M-scaler that doesn't need ferrites
Depends on the depth or your pockets, MScaler switching inputs and DAC mode output to a preamp means your paying for a lot of high end stuff to simply bypass it ?I suppose, if putting it into DAC mode , meant standard 2V output at line output, should keep everyone happy.
not a big issue, is it?
Various opinions are all valid, but there’s plenty out there with extensive vinyl collections, not to mention the current upsurge in popularity of the format that still want good digital reproduction as well, so more about appealing to as wider audience as possible than further dividing digital and analogue, there’s original analogue versions I prefer to remasters, both analogue and digital, and also digital versions I much prefer to analogue, there are those who say spending more than $xx on a DAC is a waste of money while others buy turntables that cost more than a Dave/MScaler, in the end it’s all about music and how it makes you feel.Why only a line level output?? The volume control doesn't cost anything. (just software) put the DAC in DAC mode if you want a less transparent sound and to waste money on a pre-amp, interconnects and a power cable. The "perfect DAC" should have a widely adjustable output voltage range or gain range (like the TT 2) so that only a few db of digital attenuation is required imho.
Qutest already has a volume control, it just has only two positions. The pricing is all marketing/positioning.Compare the price of the Hugo2 with the Qutest for “much extra expense” ?
4 positions..Qutest already has a volume control, it just has only two positions. The pricing is all marketing/positioning.
They are not volume controls, they are compatibility modes. If you choose to use Qutest with an amp, then the amp will control volume. If you choose to drive headphones directly, then you will use a software digital volume for control (eg. HQPlayer)Qutest already has a volume control, it just has only two positions. The pricing is all marketing/positioning.
I understand. My point is, the voltage output is controlled by software in both Qutest and other Chord dacs. There would likely not be significant additional cost associated with adding a volume control to Qutest since the software already exists. But you can think of it as very limited position volume control. If you added 60 more “compatibility modes” you’d be there.They are not volume controls, they are compatibility modes. If you choose to use Qutest with an amp, then the amp will control volume. If you choose to drive headphones directly, then you will use a software digital volume for control (eg. HQPlayer)
You seem to not realize that nothing is ever bypassed in Chord DACs, no matter what output you choose. There is no separate amp stage from the DAC output. The different ‘modes’ are simple digital settings for convenience. It’s not like conventional DAC/amp combo’s. No one else does it like Rob’s designs. Think of all of the different modes as listening to the line-out from the DAC. There is no waste of unused components.Depends on the depth or your pockets, MScaler switching inputs and DAC mode output to a preamp means your paying for a lot of high end stuff to simply bypass it ?
You will never get something different with Rob’s designs though, because they already incorporate the simplest output from the DAC, with the bonus ability to also drive transducers without adding more output stages. It’s already a reference DAC only. Again, it’s different from everyone else’s designs.Using the MScaler makes all the inputs redundant so I’m talking more about a “reference” DAC only version of the Dave, basic coloured lights for input sample rate and a simple fixed output … not one that’s capable of driving speakers as well like the Dave and TT2
Firstly, no body can possibly know how good the headphone amp in Hugo is, because there is not a separate headphone stage as such - its integrated into the DAC function directly. You can't remove the sound of the headphone amp from the sound of the DAC, it's one and the same.
This is more what I’m thinking:You will never get something different with Rob’s designs though, because they already incorporate the simplest output from the DAC, with the bonus ability to also drive transducers without adding more output stages. It’s already a reference DAC only. Again, it’s different from everyone else’s designs.
Edit: The following is regarding the Hugo, but the basic design is the same for all his DACs.
From the first page of the new Qutest thread here …
Qutest is a UK made stand alone digital to analogue converter based on our multi award winning Hugo 2 technology ….
And
Pair Qutest with your headphone amplifier to tailor the sound to your liking, or connect to your amplifier for the purest audio experience …
And
The new Qutest greatly improves on the previous 2Qute and user comments on the forum has helped shape its development…
Looking forward is there a possibility, maybe when such a thing as “Dave 2” eventuates, or sales of Dave eventually slows as everyone who wants and can afford one, owns one, could we see a “Qutest 2” and changing the first line to “:a stand alone digital to analogue converter based on our award winning Dave technology” …
Is that clearer ?
