Watts Up...?
post-12883600
Post #166 of 1,799
Mython
How does that get you three separate two-channel signals to feed into the Mojos though (for 5.1 surround)?
Actually, I'm going to confess that I never pursued that topic further, so I admit that I'm not sure if/how there is a way to get true 5.1 using those adapters. You could try PMing Romaz - he's a very astute audiophile and will tell you if it's possible.
post-12883625
Post #167 of 1,799
LaMosca
No worries, I would like to know and will try PMing Romaz to see. However, the setup would likely not be wife-approved or in the budget (as much as I would like it to be)
Maybe by the time we have the basement finished and a listening room/theatre setup there will be a nice solution. Likely 5-10 years away so they have some time to work on it, lol
Reactions: Mython
post-12887243
Post #168 of 1,799
phonyx
  I was replying to a post in the Dave thread, and my reply started to get pretty big. So I have turned it into a blog post about how pulse array works....
That is one of the most intense posts I've ever read. I haven't designed and build circuits for years, but it is such a privilege to read this, written by a designer, on a public forum; a really neat explanation of the design fundamentals of a new product.
Colour me impressed. Just wish I could afford a DAVE now!!
post-13146268
Post #169 of 1,799
ecwl
Winnipeg, MB, Canada
I was thinking of all the great achievements accomplished in the new Hugo 2 and Blu Mk II that were real shockers to me.
Sure, the new Xilinx chips help. But 1 million taps for 16fs WTA filtering in the Blu Mk II. Can't wait to see what the boss Rob Watts has to say about what difference that makes to the sound of DAVE. It sounds like John Franks and Rob Watts just decided to go all in on the Blu Mk II.
But to me the true shocker is Hugo 2. That must have required a lot of programming and testing on the FPGA. 49152 taps presumably for 16fs WTA filtering (unless it's switched to 256fs like DAVE). 10-element pulse array instead of 4-element. I'm guessing Hugo 2 no longer runs a 5th order noise shaper given the specifications. And then the incorporation of the capacitor-removing DC servo with FPGA from DAVE's design. I presume the DSD playback is still decimating but the incorporation of additional filter options was also an interesting design choice.
Just amazing. Now I worry that for those who want to purchase the digital amp, we could have saved some money on Chord DAVE and just go straight for Blu Mk II instead...
So many great products in such a short time span. Maybe DAVINA ADC and digital power amp will arrive by 2018. Here's hoping...
Reactions: maxh22
post-13146701
Post #170 of 1,799
DaveRedRef-III
UK
UK
Great news!
I can't wait to hear the new Blu Mk II. This was exactly what I wanted This is a smart move by Rob and Chord also imo. It leverages the technology and will enhance the brand significantly in the right audiophile circles.
Good to see a British company leading the field.
post-13146737
Post #171 of 1,799
DaveRedRef-III
UK
UK
2 years ago this was almost the stuff of science fiction! Haha
post-13150760
Post #172 of 1,799
Last Summer and Autumn has been an incredibly exciting and busy journey for me; and I couldn't talk about it. Now that the Blu mk2 has been launched, I now am at liberty to talk about it - its been somewhat frustrating not being able to talk about it, as the improvements have been very exciting for me.
Here are the slides from the technical presentation I put together for the press, together with some extra notes explaining things more. Firstly apologies - this is complicated stuff, and not easy to get across.
OK this slide should be familiar to anybody that is aware of the WTA filter. What I am trying to say here is that a DAC job is not about reproducing the sampled digital data - but about recovering the signal before it was sampled, i.e. the original analogue signal in the ADC. The interpolation filter has the job of recovering the original analogue signal, as it is at the heart of the process of converting from a sampled signal back to a continuous signal. I am also talking about how essential that timing of transients is too the ear and brain; if there are errors in the timing of transients (a signal's transient edge maybe too early or too late compared to the rest of the signal) then this error has massive consequences for the brain to understand the audio, and this affects the ability for us to perceive the starting and stopping of notes, the perception of sound-stage, timbre and even bass pitch (transients are used as a cue to perceive bass pitch for example - timing errors on transients mean you can not follow or perceive the bass tune).
So here I am talking about sampling theory. Basically, if you use an interpolation filter that had a sinc impulse response, then you would perfectly reconstruct the bandwidth limited waveform before it was sampled - so the sampled data would have all the missing bits in between perfectly represented - there would be absolutely no difference whatsoever from the original. So it would not matter whether you were sampling at 22 uS, or 22 fS, the bandwidth limited signal would be absolutely identical in both cases.
But to do this we of course need the analogue signal to be perfectly bandwidth limited (that's the job of the ADC - and this actually is not technically difficult to do, Davina for example will have > 200 dB of bandwidth limiting), but from the DAC's point of view we need an interpolation filter that infinitely oversamples and has infinite ringing. To do this we would need a sinc FIR filter that had an infinite number of taps; something clearly impossible to do. So to cope with a limited number of taps, I found that changing the algorithm (this determines the values of the coefficients, and that sets the shape of the impulse response, or how the ringing is defined). So hence how and why the WTA filter was created.
So I can see that maybe you are asking the question - the ideal filter rings and rings and rings for an infinite period of time, and it looks nothing like the original impulse, which is zero, a pulse, then zero. So how can one possibly say that this filter returns the original signal completely unchanged? After all everybody says ringing is bad and unnatural.
So how do we answer this paradox? Its easy - the original impulse is NOT a legal signal as it is not bandwidth limited. An impulse for CD has exactly the same level at 22.05 kHz as at DC - but sampling theory absolutely demands that the signal be bandwidth limited, and this means that at exactly 22.05 kHz and above the signal has exactly zero output - not the full output that a impulse supplies. So all this talk about ringing is fundamentally mistaken as you are basing a prejudice on a signal which a competent ADC would never be capable of supplying.
Here is the key idea - take an ideal impulse, then bandwidth limit it, so that for CD the level at 22.05 kHz and above is exactly zero, then use this as your test signal. What would happen here is that ideal filter, which rings and rings and rings with the illegal impulse, would return absolutely no difference from the un-sampled bandwidth limited impulse. And cruder filters that have short ringing will actually produce more ringing, and more changes to the original signal! So the idea that ringing of filters is bad is based on a false premise, and people simply not understanding the theory properly.
The next slide covers the WTA history - I have been talking about long tap length filters for a very long time:
So this sees the history of the WTA filter, and I will be coming back to this later.
So this talks about the new FPGA that only recently became readily available in production quantities. Now actually this design using this device actually came from the Davina ADC project, so it was easy for me to drop it in from the Davina project. So of course the secret of tap length is now out but:
The next slide actually talks about the relevance of this:
Now what do I mean about 16 bit accuracy? When you look back at the sinc function, to absolutely guarantee reconstruction to 16 bit accuracy you need the ideal sinc function coefficients to be smaller than 16 bit - and to do this, for a 16 FS filter, then you need getting on for a million taps. Now I have history on this idea. Roll back to the early 1980's when digital recordings started to appear on vinyl - and they sounded awful - hard and flat. I was at university, and was studying Electronics as a science, so we did much more theory than usual, and sampling theory was a big chunk. Now my private studies included trawling through the psychology library, and reading up on the science of hearing and perception. A common strand was the importance of transients for perceptual cues - and I learnt that it affects everything to do with enjoying music, so was crucially important.
But understanding sampling theory I immediately recognised that the interpolation filters at that time (initially NOS passive filters, then replaced with simple FIR filters) would have massive problems in reconstructing the timing of transients. I thought of it as a audio uncertainty principle (like Heisenberg uncertainty principle from quantum mechanics) when passed through a crude filter you would have uncertainty on the timing of transients that occurred in-between the samples. I actually later learnt there is a Fourier uncertainty due to windowing functions - and a window function is exactly what you do to make a finite FIR filter. By having longer tap lengths you reduce the Fourier uncertainty - exactly as my intuition told me.
Anyway, its was easy for me to calculate what you needed from an FIR filter to guarantee 16 bit performance under all conditions, and you needed getting on for 1M taps. Now in the early 1980's, DSP or FPGA devices didn't exist, the micro had only been invented a few years earlier. So the idea that 1M taps would ever be available or doable was clearly insane; its seemed like inventing a ship to take you to Alpha Alpha Centauri in a day would be more likely. So my reasoning was that it is never going to happen, and so digital was fundamentally flawed....
Now getting back to designing the filter. I have had immense problems with designing long tap length WTA filters before, and 1M taps seemed too much for the A200, so I settled on 512,000 taps, as it could be easily done. You don't want to spend months coding and designing a filter only to find that the FPGA won't work with that design.
So I got it designed, verified, got the FPGA to pass the design and meet timing closure.
Then after spending a few months over the summer I got to listen to it. Now expectations were not strong; I knew it would sound better, but I was expecting it to be just an incremental improvement.
I was very wrong.
It was massive - one of those transformational things one hears rarely.
Oh dear. This actually was a problem, as if it was just a bit better, then more taps would not benefit much. It was a problem, as we had penciled in October to launch Blu mk 2. And increasing tap length would mean forgetting that, as more tap lengths meant completely designing a brand new filter with  new architecture.
I really wanted to go for 1 million taps too, as this has been my 35 year dream. To get 1M, I had to solve two problems - meeting timing, and actually using the memory. Now there was (just) about enough memory, but when you actually use the memory, not all of it is available - so I had to figure a way to improve memory efficiency. But it was also risky, as spending 3 months more may mean it would never work.
What to do? Delay the project with something that may never be achievable? And what about all the other things I had to do (Davina, Hugo2, dig amp...) - they would get delayed.
I decided to bite the bullet, and do what I wanted top do - which is always about performance.
And December I finally got it finished - and was frankly richly rewarded. Now I do not want this to sound like some advert for it - that's not my intention and forgive me if it comes across that way - but the change in sound is not small. Everything benefits - clarity is the first thing that hits you - then focus and depth, then more refinement and timbre variation. And I can't get it out of my head as to why it's so massive - but relating technical errors to sound is very interesting - and the ear/brain is amazingly sensitive.
So the next slide is the internal architecture of the new design:
So this gives you a flavor of the well over half a million lines of code that goes into this and the complexity of it.
Finally is a discussion about Dave, and why I can't easily drop this FPGA into a DAC:
Now depth perception is a major thing with Dave - and that is down to resolving small signals absolutely perfectly, with no changes in amplitude. Having a chip next to the pulse array elements injecting 10A peak of weakly signal correlated current would destroy that ability, so using a separate M scaler would be easily the best sounding option.
The USB M scaler is actually Davina. I knew at the start of the Davina project that M scaler mode would be an important mode of operation for it; indeed, the Blu mk2 project could only be justified because of the future release of Davina. After all, a USB input is what I really need personally - but Blu has a SPDIF BNC input, so that is how I currently listen to my newly discovered music collection - yes it is that profound a change.
What is also odd is that older CD recordings sound very much better - now my high res downloads are also better, but not like 16 bit. Indeed, my feelings are that sound quality is now almost completely dependent upon the recording process and not the actual sample rate used. And the 1960's Decca's and Mercury recordings - well some of them has been transformed. I am really amazed at the quality of these recordings - now they sound obviously a bit distorted, and are noisy - but they do things that modern recordings at 192 kHz fail to do - and that is reproduce speed and impact of dynamics, and variation in timbre. In short, these old recordings have life and vitality - and this has become more apparent to me with the M scaler.
Why would that be so? Well simply put - this is the first time that 16 bit has actually been reproduced to guarantee 16 bit accuracy of the timing of transients. So for the first time we can actually perceive what 16 bit is actually capable of. But where does that now leave us? How many more taps do we need? How close is 1M to ideal?
That is the question I aim to answer with the Davina project - I will make 768 kHz recordings, decimate it down to 48 kHz, M scale it back up to 768 kHz, to create another file. So we will know for sure what these losses actually represent subjectively by comparing the two files.
2017 should be very exciting.....
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-13150824
Post #173 of 1,799
rkt31
great. waiting for m scaler for Dave. may be I am able to buy both in future. one question , could that m scaler be used with other dacs also ?
post-13150912
Post #174 of 1,799
AndrewOld
Rob, it is wonderful that you done all this work and delivered the possibility of even better sound from our music. But as a very happy DAVE owner can I ask you to please consider making the WTA M scaler available separately from the Davina. I am not going to buy an Blu2 to get the WTA M scaler because I don't want to pay for a whole load of CD reading technology that I won't use. Similarly I don't want to buy a Davina to get the WTA M scaler because I don't want to pay for an ADC I have no use for. So please think of us DAVE owners; we've spent a lot of our money with Chord, surely it is reasonable for us to expect this new million tap magic to be available in a package with little redundancy and thus less cost.
post-13150974
Post #175 of 1,799
Kamil21
I am sure it is just horses for courses. I was going to buy a cd transport for Dave and was very happy with the Blu2 announcement.
Similarly, no ADC is complete if it is not equipped with a compatible DAC for monitoring.
I am sure that one day, Chord will come out with a standalone M-Scaler, but for now am happy that I can get this kind of quality upgrade without having to replace my newly purchased Dave. If I have to wait another year or so to get an M/scaler for 10% less, it's not going to happen.
post-13151132
Post #176 of 1,799
hifuguy
Hi Rob, John & everyone... Fascinating reading as always regarding the inside-story and design insights that went into the new Blu player and the implementation/capability/results of its new FPGA.
Very humbly, I was hoping you could turn your attention to the other end of the spectrum... the amazing Poly. I sense there is an equally amazing technical story to tell here and I for one would love to hear it. I LOVE my Mojo and I use it everywhere; at home speaker-based, at home headphone based and on-the-road IEM-based listening. I was just getting ready to invest in a MicroRendu and high-end power supply to get the most out of it at home (using Roon), when low-and-behold, along comes Polly. So I have slammed on the brakes!
The burning question is how does Poly sound, when compared to other sources driving the Mojo? There's a lot of RF and groundplane activity in something as complex as Poly. You have often spoke of how Mojo benefits from being optically driven for these reasons. So how does Polly really sound compared to these things and even something as advanced as a MicroRendu? I have a feeling that Poly is something very, very special, but nobody really knows it yet. Could you let us in on all the gory, amazing technical details and give us a hint of what it sounds like please?
post-13152975
Post #177 of 1,799
Sure - M scaler can output all multiples of the incoming sample rate. You just need to select a rate for your DAC.
Having said that, for sure you will get the max benefit from using Dave, as that WTA filters to a further 256FS, then filters to 2048FS, so this timing resolution maximizes the performance of the M scaler. So I am unsure how much of an improvement one will hear when using other DAC's - clearly you will hear an improvement, I just can say bu how much.
Rob
post-13152998
Post #178 of 1,799
I have already looked into that, and its possible that eliminating the ADC won't actually make a great deal of difference. The majority of the BOM cost is metalwork, FPGA, PCB and power supply. The ADC savings (analogue integrators and pulse array) is actually quite small and would probably be outweighed by the costs of producing two products.
I want as many people as possible to enjoy the benefits of M scaler tech, so we are trying our best to reduce costs.
Rob
Reactions: Mython
post-13153029
Post #179 of 1,799
analogmusic
Thank you Rob, I would like to enjoy the benefits of Mscaler, but it needs to be affordable (especially since Dave is quite expensive and just got more expensive since Jan 1 2017)
FWIW, I personally do not need expensive metal work. It can look as plain as it can be if it reduces costs.
The question I have now is
Mscaler with Hugo 2
Jriver into Dave
Which will sound better?
post-13153037
Post #180 of 1,799
rkt31
would that stand alone m scaler be priced higher than Dave ? 1M taps for red book seems to be extremely promising but a lot will depend upon the cost of m scaler .
Users Who Are Viewing This Thread (Users: 2, Guests: 5)
