Sorry to resurrect an older thread about a sensitive company, but at this point in the game, is it pretty much guaranteed that a Singlepower that was built in the last couple years will most likely need inspection/work? I heard mrarroyo's several years ago and it sounded incredible to my ears. There are several currently available at prices that surprised me and I have really wanted to try tubes, but I don't think I could afford the repairs if necessary. Am I better off going with an amp with a better reputation?
Warning About The Singlepower Extreme - Owners Please Read
- Thread starter n_maher
Hooster
- Nov 4, 2010
You already know this, but you get what you pay for. If you just want to play around and experiment it might be great. If I wanted to a component that I could buy and forget about and expect day in and day out reliability from I would look elsewhere. You are however not me and as they say, YMMV.
mrarroyo
- Jul 27, 2005
I would try a different manufacturer unless you are buying a rebuilt Singlepower by a know repair shop. I still have my Singlepower MPX3 SE Slam that has been made safe and I love its sound, you may want to look into Mapletree amps by Dr. Lloyd or if you want to spend the moola Red Wine Audio amps.
spritzer
Member of the Trade: Mjölnir Audio
- Aug 22, 2002
Claims that the earlier SinglePower amps are better built than the later ones aren't based in reality, even the first ones have serious issues. Granted, Mikhail wasn't quite as mad in the beginning so no +500VDC on normal 6SN7's fed through a 117V rated switch as the "HV option" or other crap like that.
Thanks everyone. I think I will scratch two itches at once (tubes and DIY) and try a Bottlehead Crack kit, maybe a Bijou. Added bonus of learning more about how tubes work by DIY.
Hooster
- Nov 4, 2010
Sounds like a good plan, enjoy.
P+D-MI
Of the singlepower amps that I owned or heard, you can do better for the money. imo.
Inter
- Dec 17, 2004
I have a Singlepower MPX3-slam and I was wondering if anyone could tell if this is one of the safe ones? Never had much trouble with it, except for some noise in the right channel every now and then. It gets quite hot but I've used it for years..
spritzer
- Aug 22, 2002
We would need detailed internal pics to know if it is safe or not.
Inter
- Dec 17, 2004
Ok. Thanks for the input. I'm not sure if I am proficient enough to get the lid off. Not seen these particular screws before..
spritzer
- Aug 22, 2002
They are hex (or Allen keys) and a small imperial size. To make matters worse the screws are glued in place as Mikhail didn't want anybody to see what was inside.
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
drilling out the screws is lots of fun. They are hardened steel and in addition
to everything else, they rust.
DefQon
- Jan 14, 2011
How well do the old MP3X SE with Supra upgrades fair up against today's tube amp's within $1k?
spritzer
- Aug 22, 2002
If it has been fixed by somebody who knows what he's doing then it's a good amp. If it's still stock and/or gone over "by my tube tech" or some such nonsense, stay away.
DefQon
- Jan 14, 2011
Thanks for that, there is one listing in the F/S section which I assume is a slightly later model (2006) by Mikhail as it comes with the HV option and supposedly it's been working fine since the user bought it back 6 years ago. Although I have no experience fixing up Single power amp's, I'm willing to open it up and post pictures here for you guys to see if part's have been wired up within spec or properly. I feel at worse it will be needing a rebuild or such.
