Originally Posted by ericj /img/forum/go_quote.gif
Through them to where? Ground?
Yes. Fallen Angel is absolutely correct.
One way to look at it is that the Anode (Plate) is always supplied with a much higher positive voltage. However, the signal voltage - which is carried through the grid - is necessarily AC, and so varies from positive to negative according to the frequency of the signal (music). In order for this to take place, the cathode portion of the tube has to "accept" the negative dips of the signal. So, a large part of the signal waveform is always somewhere between the grid and the negative ground, which passes through the cathode. When a resistor is applied to the cathode, some current actually flows from the plate, biasing the tube (Class A operation). A capacitor is used to "bypass" this resistor so that the AC portion of the signal passes through the capacitor, and the DC bias current is maintained through the resistor. Hence,
cathode bypass.
The result is that a very small current and voltage exists through the capacitor, but it is almost all signal. In addition, the combination of the resistor (often just a trimmer) and the bypass capacitor forms an RC filter. So, the capacitance must be high to keep from losing the bass frequencies. This usually means an electrolytic, and a quality, even "boutique" capacitor is warranted.
EDIT: This is also the reason that so much DC is freely passed by vacuum tubes. Unlike solid-state circuits, which take DC separately and use it as amplification
leverage, it's all superimposed in a tube circuit.
