Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Discussion in 'Portable Source Gear' started by vapman, Dec 8, 2016.
83 84 85 86 87 88 89 90 91 92
94 95 96 97 98 99 100 101 102 103
  1. Ruben123
    Well the walnut does roll off on both sides. And depending on your earphones you might hear more or less noise. Completely normal
  2. Ruben123
    And do you get 40 hours with those?
  3. flamesofarctica
    Is there a link, as I can't find it, do they have a store other than on Ali?
  4. vapman
    You betcha! I only have 3 earbuds 150 ohm or higher.
  5. vapman
    Check post #3 i used the link there earlier today.
  6. Ruben123
    That's nice. I too still have to charge nice and have it for 2 weeks already. Though I don't listen to music that often, max 2 hours a day.
  7. neog007
    Wow! It seems you're gonna make a completely different player! Maybe the walnut v3.. ? [​IMG]
    anyway it'd be amazing if you apply some of this mods to the zishan -but I guess it's not as easy as with the walnut because the lack of space-
  8. vapman
    Plus all caps and stuff on walnut are through hole, so nice and easy to work on. not like SMD....
  9. neog007
    yeap the walnut is like a raspberry Pi' player so great and an easy path for those of us that want to push up the best possible sound
    kfarndog likes this.
  10. LionPlushie
    i have it in my cart but when i check it still says out of stock tho..
  11. flamesofarctica
    Similar but different when I tried - it says unable to add to cart, please refresh.. then if I try to refresh, opens the item (unavailable) in the app. No sign of CKLewis when I search on 'DIY MP3', and no sign of walnut if I order CKLewis all items by price.
    I don't need to place another order as such, it's just an order I have with another seller (for a friend as he didn't want to use Ali himself!) seems to have stalled so I was guessing stock issues, and I was hoping that a restock had appeared :-D
  12. fumoffuXx
    Hey guys i tried the 860 it was good but it gave the player an irritating floor noise. I changed to AD823, the bass  wasnt as tight and have a slight decay, BUT SILENT background noise :D amazing! Using with AAW A1D :)
    To add: no more popping sound when turning on and off :D
  13. LaughMoreDaily
    Yeah, it doesn't look like Lewis is selling it anymore... but, if you search for the Walnut on Aliexpress, you will find it!
  14. flamesofarctica
    Finding it on Ali doesn't always equate to seller has it in stock unfortunately. And from the occasional experience, sometimes you even find that out after you've had a tracking number :-D
  15. bzfrank
    Try the AD825 instead of the 823.
