Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Discussion in 'Portable Source Gear' started by vapman, Dec 8, 2016.
43 44 45 46 47 48 49 50 51 52
54 55 56 57 58 59 60 61 62 63
  1. navydragon
    Can't wait to receive my 2 units and join the club. :)
    Sent from my LG-D855 using Tapatalk
  2. musicday
    Guys in order to make the group on Wassapp i need your numbers.PM for details.
  3. fajrinandro
    So.....
    Ijust heard the default walnut sd card chinese song provided by iJay (because mine doesn't come with it), and it's amazingly refreshing and calm playlist. I can be sure now, that my walnut can play the wav files (i only have 320 mp3 and flac colletion). If only i can understand the lyric, it'll be perfect :grin:
    iJay likes this.
  4. iJay
    I'm in. I'll download and PM with details.
  5. musicday
    The Wassapp group is open for anyone who wants to join in the Wallnut V2 Discussion.
    vapman likes this.
  6. the diode
    Mine cleared customs in the US. Hopefully not much longer. I am ready to try this out.
  7. sfogar
    I hope you'll stay here ...
  8. big45-70
    How do I buy one of these?
    *edit
    Never mind I found multiple with google-fu
  9. Spider fan
    Lol, wow finally tried it as an amp.  I am about to watch Vikings on my laptop using my hifime 9018 Dac > walnut > HD600.  I can only turn it from like 7(no volume) to 9 and it is bordering on too loud.  Stopped my show and pulled up foobar and I could only go from 7 to 8 and its super loud.  Obviously, at that point I turned down my computer so I could use more of the walnut's volume pot.  This thing is a powerful beast.
    Sucks for my Matrix M-stage I just got last week.  The walnut is a million times more convenient to use and at this point seems more powerful.  Not that that matters since both get way beyond what I would I would listen too.  Will be interesting to A/B between them for sound quality.  All I know so far is I enjoy what I hear out of both of them and that is all that really matters in the end.
    Still cant believe I was walking around the house listening to my Zen 2.0s out of a dap.   I've never done that because I didn't want to lug around an amp too.
    Whenever its apparent the maker is on their final version,  I will buy a few extra to tuck away for the future.
    nick n likes this.
  10. avitron142
    I just got my Walnut, it's really, really good. Detail is absolutely on point, and I'm not even bothered by the slight "digitalness" (it is very slight) that the others have mentioned. It's an excellent pairing with the Pinnacle P1, and really punches way above its price range.
    Only problem is, returning to listening with the P1 with my computer, I think I'm noticing a slight channel imbalance, which is worrying the heck out of me. It could be my computer, my ears (just took a shower), or anything else that doesn't have to do with the headphone, but I can't help but think... is it possible that the high impedance output or the popping signal ruined my headphones? I really loved the P1, and it could be I'm imagining this, but I'm kind of scared of the possibility. [​IMG]
  11. vapman
    The high impedance -might- make a difference (just assuming because they're in ears) but the pop shouldn't damage anything. If you are worried you could plug in some crappy headphones after first power on, so that "absorbs" the pop.
  12. avitron142
    Yes, but they aren't BA's, they're a single dynamic driver. I just hope I'm just imagining things as I'm tired, and didn't destroy part of the drivers in any way xP They pair excellently together, and sound absolutely phenomenal, but I kind of want to also keep the headphones intact, you know? [​IMG]
  13. vapman
    I hear you. If you're using any IEM you should probably use the digital volume control by holding "Prev" to lower the volume. If you're using it as an amp, well, you would probably need to turn down your source considerably as it runs at full power which makes full size headphones get uncomfortably loud.... it will blow out IEMs at max volume!
  14. avitron142
    For sure! I kept the knob at very low, adjusted the digital volume, and then raised the physical knob when necessary - which, by the way, turns very smoothly, and has a very accurate level of resistance. Thanks for helping my make the choice to buy this, it's a superb DAP for sure!
  15. flamesofarctica
    I managed to turn off my Walnut with my Asura in, scary, and then forgot about the pop when I plugged them in to check they were ok. I won't make that mistake again, but I think they're ok.
    Can't say I wasn't warned.
    With a lack of 'phones I really hate I think I'll save the one set of Monks I've been using (I have so many spare sets) as my 'Walnut absorbers' for first plug in. They're no wimps anyway, I'm sure they can withstand it!! But I really won't be turning on / off with 'phones in again, it wasn't very pleasant :-D
