Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-13665954
Post #3,286 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
i think the real question is:
who ordered an F1 and has anyone that ordered received theirs yet?
I ordered mine on 2017.08.06, from CKLewis Audio Store.
The first shipping status appeared six days later.
There may not be another status update, until it's here in the USA.
2017.08.12 10:00 (GMT-7): 【8】Received by line-haul
2017.08.12 21:30 (GMT-7): 【CHINA】Acceptance
2017.08.13 22:55 (GMT-7): 【CHINA,GUANGZHOU EMS】Processed Through Facility
Reactions: dmz555
post-13669017
Post #3,288 of 3,580
Ivan TT
New Zealand
New Zealand
anyone here who can give an impression on walnut f1?
Im wondering if walnut f1 plus burson v6 vivid will sound good on its 2.5 balanced PO.
F1 Looks good, even if it's not obvious from the photo that it has Muses02 now :wink:
I will only get V5i and V6 (but not vivid) early next week, hopefully 2.5mm cables will turn up soon too.
Reactions: dmz555
post-13669047
Post #3,289 of 3,580
noknok23
Netherlands
Netherlands
F1 comes with muses02???
Edit sorry I saw its op2134
I guess zishan z2 with muses02+walnut F1 burson would sounds huge??
I wonder how F1 compare to bluebird amp
post-13669355
Post #3,291 of 3,580
dmz555
Philippines
Philippines
Thanks Ivant TT, look like z2 and f1 are getting along really well. Does the balanced 2.5mm PO sounds better than the 3.5mm se?
post-13669723
Post #3,292 of 3,580
Ivan TT
New Zealand
New Zealand
Still waiting for 2.5mm cables, stay tuned.
Reactions: dmz555
post-13670624
Post #3,294 of 3,580
hydroid
Getting more and more excited while waiting for my F1. I almost have identical setup with what you have. I have Z1 though with muses02 and ch9t for now while waiting for the F1.,Anyway, did you place the muses02 on the F1 for the 2.5 balanced output port?
Reactions: Ivan TT
post-13670625
Post #3,295 of 3,580
Ivan TT
New Zealand
New Zealand
Getting more and more excited while waiting for my F1. I almost have identical setup with what you have. I have Z1 with muses02 and ch9t for now while waiting for the F1.,
I moved muses02 into F1 and had to employ 100ohm attenuator - too loud!
Using PO instead LO sometimes provides VERY interesting results, and sometimes is necessary, especially with CH9T that extends LF all way down to the centre of the Earth. :wink:
Reactions: hydroid
post-13670639
Post #3,297 of 3,580
Ivan TT
New Zealand
New Zealand
A thing of beauty indeed.
Agree, and holding it feels strangely satisfying, go figure.
That's the 2.5 balanced ch9t isn't it?
Yes, although I'm not proud of the cheap plastic jack or my soldering skills.
Any significant difference on sound quality between SE and balanced output?
SE is weird on F1, it may be that my unit is defective, but I doubt it.
Balanced is sweet, I'm still going through my reference tracks, but overall impression is positive. Very positive, actually. It's good that you have CH9T, actually - anything of a lesser quality would simply make it not worth your while...
Reactions: hydroid
post-13670655
Post #3,298 of 3,580
hydroid
Good to hear that the balanced out is sounding great.,Not expecting much on the F1 SE though as the Z1 SE produces a satisfying audio quality for my ear.,.Just ordered the F1 solely for the balanced out and I'm glad that I made the order.,.thanks for your input and prompt response bro. :)
post-13670656
Post #3,299 of 3,580
Ivan TT
New Zealand
New Zealand
Overall F1 is a mixed bag for me right now...
I had to employ a 100ohm attenuator as when used with Z2's LO F1 is obscenely loud on the balanced out, so much so that only about 10% of potentiometer travel is usable and it's a safety hazard. It distorts when using se (3.5mm) out. Too much bass (at least with muses02), but it depends on the recording. This will require tweaking/fixing, I'm already thinking about adapting buffers for se out (drv134pa allows for this by grounding L- and R- I believe, but the trick is to not to lose balanced out).
But when you find a sweet spot on the balanced out... it's absolutely wonderful, full-bodied, layers and layers of sound, bets sounstage ever, details I never heard in the recordings I know by my heart. It works well on some tracks Z2 struggled with and anything hi-rez (especially DSD) is totally immersive.
post-13672404
Post #3,300 of 3,580
dmz555
Philippines
Philippines
Thanks for the update Ivan TT.
Just for claricifaction.
Out of the box does the 3.5mm SE PO sounds weird? Or it only started soundingweird when you installed muses02 opamp?
Have you encountered any weird problems in its 2.5mm balanced PO when using stock opamp?
I hope you can enlighten us.
Thanks in advance!
