Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-13504133
Post #3,018 of 3,580
nesty
Hey, has anyone been able to mod the Walnut when using it as an amp? It is sooooo loud. Is there a way to lower its initial volume. I tried the Z1 into Walnut combo and nearly blew my head up.
Have you tried the other way around, I mean source would be walnut into z1 then z1 is the audio headphone ? Thanks
post-13504411
Post #3,019 of 3,580
macky112
SoCal
SoCal
It has been mentioned a few times over at the z1 thread that z1 sounds better than v2 when both in stock form. That said if you have both z1 and V2, I don't think it makes much sense to use V2 as dap into z1 amp
Just use z1 as dap
post-13504446
Post #3,020 of 3,580
Dark Helmet
Ppl, my 'nut is kinda broken...
It's the headphone jack, if I stick the connector all the way in, left channel is dead, but if I then pull the connector out slightly, sound seems ok, maybe left channel is still softer, could be placebo tho
Is there an easy fix? Or I need to replace the jack?
One of the resistors towards the edge of the board for the headphone out is bad. I had this happen to me and had it replaced and it works fine now.
post-13504454
Post #3,021 of 3,580
Dark Helmet
Just got my Nut!!! It's the old ver V2 with the hold switch. Yet to try though ... charging it first.
Will changing just the Opamp makes a big diff? Any suggestion? Love vocals, opera, R&B and Korean OST ...
Looking at either the Philips NE5532AN or the the AD825AR
Thanks
Both are good the 825 will be a bit fatter and warmer. The NE5532AN I think for this application sounds better.
post-13504618
Post #3,022 of 3,580
silverfishla
Los Angeles
Los Angeles
Just use z1 as dap
I actually meant, just V2 as amp, since it is so loud. Any source that isn't variable just blows the ears away through the V2 as amp, making that function a bit unusable.
post-13505091
Post #3,023 of 3,580
macky112
SoCal
SoCal
Not sure about hardware change, but a software solution is to apply negative pregain to your sings in foobar2000
I mean, if you have a 'nut, you are already converting sings anyway, might as well make another batch conversion for negative pregain
post-13505100
Post #3,024 of 3,580
macky112
SoCal
SoCal
When looking for those s bad resistor Is a bad resistor acting like a short circuit or an open circuit?
post-13505125
Post #3,025 of 3,580
macky112
SoCal
SoCal
post-13505516
Post #3,028 of 3,580
minnyB
I noticed official Walnut taobao listing updated his product page
https://m.intl.taobao.com/detail/detail.html?id=542124740337&fromSite=main&spm=a312a.7700824.w4004-15832814554.3.RfsAtQ
And USB DAC function was not mentioned anywhere on the page...
I thought V2.2 and V2s have USB DAC right? Otherwise another reason to go for the z1
Walnut V2s has USB soundcard function. Turn on Walnut V2S first. Connect Walnut V2S with USB cable to your PC/mobile. You can adjust volume level on your Walnut V2S.
If connecting to PC, don't forget to disable your PC's sound card.
post-13505619
Post #3,030 of 3,580
ozkan
