VSonic GR07 Bass Edition Impressions
82 83 84 85 86 87 88 89 90 91
93 94 95 96 97 98 99 100 101 102
  1. Tanjent
    Will my Clip +  and E6 be able to drive the Bass edition being 40 ohms?
  2. JoeDoe
    You should be fine. I've been using my Clip + with an E5 with no problem.
  3. imackler
    Your Clip would do fine job alone! Between the Clip and E6, it will be more than enough. The Clip is quite good; I'd try it both ways and see which you like the most!
  4. Tanjent
    Sweet will do when I finally get the Vsonics...
  5. modulor
    I agree, this is how I run mine, straight from a RockBox'd Clip+.  I found that an amp is not really necessary from those I tried.  Something like the RE-262 needs an amp.
  6. Tanjent
    So the sensitivity has a lot to to with drive-ability also....
  7. modulor
    A bit, that IEM in particular has pretty high impedance with low sensitivity and it's just power hungry.  Check out this posting: http://www.head-fi.org/t/17179/please-explain-headphone-sensitivity  To reiterate,  my understanding is that high sensitivity headphones are capable of drawing more power from a well-paired amp at the same volume level, so they are more picky as a result, which is why you often find that lower sensitivity is more commonplace and better in portable applications that are using lower power devices.  Also, the nominal impedance number listed (40Ohm in the case of the BE) is not exactly accurate for every frequency and every power output, and is more or less an average.  It can get a bit tricky to figure out as you can see, I still don't fully understand but I'm learning haha, so I hope this all helps a bit.
    I imagine that the Clip+ would be able to drive the RE-262 to listenable levels no problem, but it would only have like 3 hours of battery.  In that case an amp would not only afford more battery life, but because of it's high impedence the extra power would tighten it up a bit and clean up the sound and have a pretty audiable improvement overall.  I suspect a good portable amp could do that as well with a GR07, but I personally can't say how much of an improvement it would make.  I unfortunately don't have much experience with portable amps at this time, or with higher impedence cases like the RE-262 for that matter, that is just what I read of it when I was researching IEMs (and I ultimately chose the GR07 at that time).  I am working on a CMOY-style amp at the moment though for practice, and with good quality components [​IMG] so we'll see how it pans out and if there's much benefit.  Others may be able to add in their results from their portable rigs, but from personal experience I feel the BE is quite good right out of the Clip+ or any other portable player I've tried.  Here is a good article about amping, so that may further answer some questions: http://www.inearmatters.net/2008/12/to-amp-or-not-to-amp.html
    I do eventually want to refine my portable rig, but since I'm focusing on getting the desktop setup squared away I have to put that on the back burner (and I'm undecided on how to proceed anyway so it needs more research).  What I'm currently using though is pretty fantastic I must say for what it cost.
  8. Tanjent
    Thanks Modulor..I will checkout those links....
  9. mochill
    January 1 four new iems will be released by vsonic :D , get excited my friends :)
  10. Tanjent
    Any links?
  11. mochill
    The links on my galaxy tab 2 and not on my z walkman player which I'm using atm . Sorry
  12. Tanjent
    No worries
  13. mochill
    If your looking for an open back gr07 bass edition get the phillips fidelio x1 , I just switch the stock cable to the monster icable 800 and I got say :
    o
  14. Tanjent
    No good for the train I suspect
    jaybird123 likes this.
  15. hi-fi amateur
    You suspect the vsd7 will be included in that release? That's the one I'm eyeing :D
