Vorzüge VorzAMP PURE II - review and impressions
post-10842077
Post #256 of 828
l3loodshed
guys what are the comparisons between the Pure II, Tralucent T1, SR-71b and the Alo Rx Mk3-B+? can't decide what to get
post-10842433
Post #257 of 828
fiascogarcia
Living the Rocky Mountain Way
Of the 4, I only have the Pure II (SR-71A is the only other similar that I have), but one thing you might want to consider is if you want to go balanced or not.  That might narrow down choices.
post-10842853
Post #258 of 828
l3loodshed
 hmmmm balanced would better, I would rather go for balanced but if the SE is pretty good i wouldn't mind going down the SE line hahaha
what's the comparison between the SR-71A and Pure II? can the Pure II drive cans like LCD2 or the LCD3?
post-10842924
Post #259 of 828
maricius
Why don't you check out the Cypher Labs Duet? Its balanced output and SE output is stronger than the ALO and has similar quality to the Pure II (what differs is the note presentation and soundstage presentation). What source will you be pairing the amp with?
post-10843041
Post #260 of 828
l3loodshed
Line-out from my HM-901, cause my HM-901 dies too fast and gets warm too quickly so yeah, wanted to get an amp to reduce those issues (And hopefully at the same time improve the SQ and maybe provide the driving power that my HM-901 is unable to give for demanding headphones)
The Duet sounds like what I need in terms of function, but may I ask how does the Duet differ from the Pure II in terms of note presentation and soundstage presentation?
post-10843053
Post #261 of 828
maricius
Check this post by WCDChee.
post #242
I couldn't have said it better, myself.
post-10843136
Post #262 of 828
Poimandres
How does the pure II compare against the portaphile?
post-10843489
Post #263 of 828
fiascogarcia
I did a brief comparison on page 15.  Don't know about the Audeze's, as I don't have a set.
post-10843833
Post #264 of 828
WCDchee
I would like to correct something i said previously. The vorzuge pure 2 actually has pretty decent driving capabilities, much better than the old vorzuge's. Even when i tried it with then hd800 and the akg k812, it managed to sound really good, definitely not the best, but decent. It was only when pairing with headphones like the hifimans that the lack of power started to show.
post-10845593
Post #265 of 828
l3loodshed
  I've now got ~40 hours on my Pure II, and the charging problems were sorted out simply by using a different charging cable (the one that shipped w/ the amp is defective somehow).  I am also re-charging by using an external battery pack (just testing it out before a long trip I am taking in a couple months); it's this one--> http://www.amazon.com/gp/product/B00D5VAYRU/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I am now getting 8.5 - 9 hours in my RWAK-100-S > Pure II > Earsonics SM64 or Shure SRH1540 rig.  I am still very impressed by sound quality, and I actually prefer the Pure II over my Rx MKIII-b on that basis.  Oh, and correct:  the front panel (white) LED is BRIGHT.  I literally used it as a small flashlight last night.  LMAO, they might be able to gain an extra 30 minutes of play time if they lowered the brightness of this front light!  I am seriously thinking of taking a black Sharpie to it.
What's your comparisons between the Pure II and MKIII-b? can't figure out which one of the amps to get hahaha
post-10845601
Post #266 of 828
l3loodshed
hmmmmm sounds like just the amp I need minus the balanced output
sorry I didn't see hahaha, read it and it sounds like my kinda thing
thanks guys really helped to narrow down my options till just between the Mk3-b+ and the Pure II
post-10845611
Post #267 of 828
awry
Erm, extra battery? Smaller, cheaper, no need for interconnects. What exactly have you been trying to drive with your HM901? Thing has quite a fair bit of power for most things. I only LO my 901 at home for a different SQ most times.
post-10846645
Post #268 of 828
WCDchee
The ALO is warmer sounding, thicker, more powerful for full sized headphones, but thats about it. Its not as refined, nor is the soundstage as immersive and large. On top of that the terrible hiss makes it very bad for IEMs. To give a gauge of the sound, the duet's signature is somewhere in between the mk3b+ ans the pure 2.
post-10855366
Post #270 of 828
shigzeo
The Hiss King
Website
ohm-image.net
I have but the tralucent has gone through a number of changes. Both are excellent. Tralucent a bit more cleanly detailed and the PURE II more moodily detailed. PURE II is my favourite of all time, but tralucent is amazing. I tested the tralucent DAC as well and really liked it but didn't have time enough with it to deliver a review.
