Volume settings question [M audio Revolution]
Feb 13, 2003 at 4:06 AM Thread Starter Post #1 of 5
DrTacoElf
What % should i have the software setting at [master volume and wave volume] with the revolution, playing songs via coolplayer heading into my CHA 47 amp at?
100% i presume?
Feb 13, 2003 at 6:06 AM Post #2 of 5
ya. unless you notice clipping problems 100% would be your best choice.
-dd3mon
Feb 13, 2003 at 6:22 AM Post #4 of 5
Your source should be set as high as possible without distorting to provide the best possible signal to noise ratio.
You should use your amp's volume control.
Feb 14, 2003 at 2:14 AM Post #5 of 5
Thanks, for the tip
