Fegefeuer
- Mar 17, 2011
V226=official V280 successor + Chronos DAC
I thought V340 is successor...V226=official V280 successor + Chronos DAC
Are you using it? I see the power specs are about the same as my V220. Are these warmer like the old style (V220/V281)?The King is dead - Long live the King!
It is the good old tubey like V280 but with slightly enhanced technicalities, more controlled, expansive, better detail and clarity.Are you using it? I see the power specs are about the same as my V220. Are these warmer like the old style (V220/V281)?
I'm reasonably sure your V220 is the single-ended output brother/design of the V281--in the same case with the same I/O & connectivity.Trivia question. I have the V220 which shares many features with the V281. If I use a pre-out to power a small tube amp, can I then use my Vio to control the volume on the tube amp?
Thanks.
I had to read that over several times, but I think I have it now. Thanks! I do have the manual in a drawer somewhere. Seems pretty straight forward.@Shane D The v220 can be set to have fixed output level (mirrored from the input) or variable output level from the volume control.
It is software selectable for using Pre-Post fader (fixed - variable) You should see the details for doing that on @ page 22 of the manual.
Here's a link to the manual < https://manualzz.com/doc/8091573/violectric-audio-hpa-v220 >
Gungnir A2 + V281 was one of the best combos I ever heard (with an HE1000).In your opinion guys, waht would be a perfect pairing for a V281 in terms of DAC?
Price quality, obviously.
Something extremely neutral, because i like the warm tonaly of the amp. Benchmark DAC3? RME Pro? Chord Hugo 2?
Many thanks guys
