zhgutov
- Dec 17, 2014
RCA and XLR inputs sound very similar, IMO.I have a question about the XLR vs SE inputs. I just picked up a Chord Qutest which is only SE outputs. I was wondering has anyone tried testing if there's a difference connecting a SE DAC using an RCA to XLR cable plugged into the XLR inputs on the amp? As opposed to regular RCA to RCA SE cables into the amp?
Of course the signal going into the amp is SE regardless of the cable or input used since it's coming from a SE DAC.
I just don't know if there would be a difference to letting the amp do it's phase conversion from the SE inputs, or using a cable that's already going into the XLR inputs?
I'm asking just in case their could be some gain in audio quality from using one or the other?
For reference I'm using the balanced HP output of the amp.
If your DAC has RCA outputs (only) it is probably better to use RCA to RCA connection.
