- Jan 29, 2010
Audio-GD's big boys like Master 9 or Master 11 should be considered too, as Dan of Headfonia pointed out
There is no Dan in my staff
€'s sent to the lakish people, and in 3 days they will ship it once money arrived.. can't wait with Hegel HD25 Nordost cables, and LCD3.
I believe you gonna love them. Recommend to drive your LCD3 with balance tho, balance out is the strong point of V281
I never run my V281 using anything other than the balanced output. That wonderful 'holographic" effect of the V281 doesn't seem to happen for me when using single ended output. I am guessing the dual amps is what is making that magic happen. I don't know of any other SS amp that does this (my previous SS amps - Taurus and 430HA - did not do it). Something that better tube amps seem to do.
I am enjoying the heck out of this amp. Current rig is Hegel HD30->V281->HD800S. Really nice setup. I can't get over the bass improvement in the HD800S over the modded HD800 - great headphone. Only my modded HE6 beats it, and not by much, and that after many hours spent modding and re-modding the HE6. The HD800S you can take out of the box, attached the balanced cable, plug it into the V281 and enjoy the music.
Here's a pic of my V281 setup.
Why not use the Hegel bypass and allow the Amp do the volume adjustment ?
I am. The display on the HD30 is the source information (USB/44).
I don't use the digital volume control at all - it is set to bypass "101" - the volume control is via the V281.
I do the same thing with my 2 channel system - the volume control is via the preamp (Hegel P20).
If they offered a version of the DAC with no digital volume control at all I would have bought that. Not sure why manufacturers feel the need to offer the digital volume control.
Because it can be useful, and if you don't need it just set to max volume. That's the same as not having it in the first place (or at least it should be on a well designed component).
So you are getting better imaging from the V281 in comparison to the others?
