Sound Eq
- Nov 9, 2013
for now I will use the internal dac using usb, to get a feel of how it is in stock form, so I was referring to the headphone amp gain +6db addition, if I should do anything in tidal or roon to prevent clipping or is that not related at all.No, nothing, just go bitperfect. The Violectric stuff takes a lot of input volume, don't worry about it.
I recommend going the PI2AES route though instead of USB. You'll get more of your V590 that way. I use a Lynx AES card to the V590 with a single W3173 Neutrik wire and the Pi2AES still came out on top. It's just a superb design.
Building a RPI4 is not a big task, also you can setup an additional one as Rooncore/Roon Endpoint etc. if you want to go all out.
