memepool
- Mar 24, 2004
I have also heard that but it seems to work very well. I am not 100% sure whether I have the "bounce" right on the suspension on my TD125 though (which is in the standard black wooden plinth). It seems rather stiff compared to a TD160 I had. I may try and get hold of some Linn springs which are pretty identical
I have heard people level the same criticism at the Ittok on the Lp12 but I have also heard of people fitting an OL Silver so I don't know. Have you tried any other arms on the TD125. I was thinking about checking out the Hadcocks and the Ittok?
If you want to try out the rega you will need a washer with the same sizes hole as the rb250 to fit the SME hole in the armboard and it helps with the VTA if it's about 3mm thick. VTA on rega is a pain.
Originally Posted by Nak Man I heard Rega arms don't match well with suspended plinth like 125 or LP12 ? |
