Thanks ! What turntable can you recommend over P2/P3 at about its price range ?
Hi Nak Man, its hard to know what the price range is? The P3 used to be about 300UKP. For this price it's pretty hard to beat as a package and there aren't many decks in this price-range any more anyway.
If you want something new I would go for a michell tecnodek but this is almost twice as much. It's slightly cheaper than a P5.
http://www.michell-engineering.co.uk...hfw_tecno.html
This is a good option if you want an off-the shelf-design, although it has the same potential lack of suspension issues.
But then again suspended subchasis decks arn't really in vogue anymore apart from the Linn and relaunched roksan xerxes (
http://www.roksan.co.uk/)
most manufacturers seem to be leaning more towards the michell skeletal approach citing lack of resonance the main reason for doing away with the plinth altogether.
The sound is certainly different, some would say less coloured. It doesn't have the same bounce but has a lot more slam in the bass.
As you like the Rega Sound you might prefer this to the sprung chassis sound. If you are prepared to do some tweaks yourself then you could find a 2nd hand Townsend Rock or the cheaper Townsend Avalon both of which can be upgraded with Origin Live DC motors and new Tonearms. This is a serious highend deck which many prefered to the Linn in the 80's.
Whatever way you go you can't escape from investing in a decent support for your turntable, but a concete floor is a good surface.
