VenturCraft Soundroid Typhoon
Sep 13, 2014 at 11:43 AM Post #331 of 343
Hi audionewbi and zachchen
Very good news from e - earphone , they make 2 different type of Typhoon with 2 prices
VentureCraft SounDroid Typhoon SDT RS 627
with op amp 627 for ¥ 64.800 Yen and
http://l.facebook.com/l.php?u=http%3A%2F%2Fwww.e-earphone.jp%2Fshopdetail%2F000000047536%2F&h=TAQEhJd0JAQHOkTPExyj5OMeKsfcb1uybcitIZNfap3kD7g&enc=AZNhibWdMOSnVfhCKU0H5y9EMRQHVunGehm2vKgkd8yHsZypOZ3IwKm1hSPmW3Zlh4mRI6KOnsdFKiuOUe050xPL0_Dawgj3rB5HM2IM4UlaTm_UHv3kCCAlXUmnsjfNgbWUz09es5VBoB2bRK_3rlR-&s=1
VentureCraft SounDroid Typhoon LTD. SDTL-627SM
With op amp SM 627 the price ¥ 98.000 Yen
http://www.e-earphone.jp/shop/shopdetail.html?brandcode=000000041596&search=VentureCraft&sort=brandname
Oct 9, 2014 at 7:28 PM Post #332 of 343
so please rudi, can you tell me about which one is the best to buy, to give a full warm rich sound, with great bass boost for my iPad to drive audeze lcd2.
Is this the best portable dac for idevices better than the entrance m8, as the m8 does not support dsd
Oct 9, 2014 at 10:27 PM Post #333 of 343
The best SQ is the limited edition with op amp SM627 for ca $ 950 USD
But the power is not enought to drive your LCD 2
Imo
Oct 10, 2014 at 4:15 AM Post #334 of 343
Imo
i can't find that limited edition anywhere, if i buy it do i need an amp with it, if yes which u suggest
Oct 10, 2014 at 8:31 AM Post #335 of 343
Please try it directly with internal Typhoon amp , if you find enough power to drive LCD 2 than no need to buy external amp
On e earphone japan you can find typhoon Limited Edition
Or you can email to Venture Craft japan
http://translate.google.co.id/translate?hl=en&sl=zh-TW&u=http://www.hkgolden.com/articles/article.aspx%3Fid%3D16105&prev=/search%3Fq%3Dventurecraft%2Btyphoon%2Br627%26client%3Dsafari%26hl%3Den
Jan 2, 2015 at 1:09 AM Post #336 of 343
hi guys, need some help... i was trying to plug in my soundroid typhoon to my macbook but it seems not working... just nothing happened... try restarted everything but still the same. My macbook can charge the soundroid typhoon but it is not using it as a USB DAC. Any idea? thanks...
Feb 4, 2020 at 11:25 AM Post #339 of 343
Not sure if anybody still using this. My Typhoon keep blinking red light when use with Iphone as Dac/amp or green for very brief period. Work fine if use only as Amp.
Sep 26, 2023 at 11:36 AM Post #341 of 343
This is an older thread and not sure if anyone will see this but I am trying to find a battery replacement for the Soundroid Typhoon. Like the recent posts, the battery in mine has died making the Typhoon useless. If anyone has a link on a battery replacement I would much appreciate the help.
Here is a picture of the battery if that helps.
Sep 26, 2023 at 5:28 PM Post #342 of 343
Here are the printed specs... still looking!
