phixion
- Jul 16, 2016
Can they be worn cable down? Over ears is a deal breaker for some.
Possible, because the Monk IEs are so small, but not recommended. Isolation takes a hit because of poor fit (YMMV), and it doesn't feel as comfortable as over-ear.Can they be worn cable down? Over ears is a deal breaker for some.
I tried, but the 2-pin plugs would make it an even worse fit. If the sides are not swapped, then you can still put on the earphones based on the nozzle angle, and get an acceptable fit (but weird looking - like people who choose not to wear the SE215 over-ear).I would think you'd be better off swapping sides to wear them down due to the look of the nozzle angle.
I am planning to buy them and I have no "real life" friends who are into audio, so sure!I'm very interested in buying the package, but as I've not purchased any Monk products before, I'm afraid I am not eligible to buy it.
If anybody buys a pair, could I get a gearcode as a reference so I can buy them too?
Yes, I am able to use the CP100 on both the Biggie and Smalls.@Lonelyers Did you try the Smalls with Spinfit tips yet? I suppose they take the CP100?
