I remember dicodes from the past. Was and probably is the best chip. Never bought because my empty wallet LOL. I had only an used provari(rip). For my actual vape i use mods with three 18650. My watt range is around 85-95 watt.There are quite a few Dicodes devices when you include those incorporating their chips. They now make a single 2x650 mod too, for those who need more power for DL purposes. Other Dicodes devices include Hellfire Shadow squonk, the Submonkey one pictured amongst mine (its a regulated 18650 squonk basically as small as a mech), The Tiny (another squonk), the Yogs E-Pipe (pictured in my post also). Most are fine for purposes beyond MTL, not super high watts vaping, but drippers and squonks running on single coils all doable.
Vape-Fi
- Thread starter AudioScream
- Mar 20, 2013
My Hellfire Shadow, not pictured in the dump above.
What's the build inside of that atty?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
NZtechfreak
- Jan 19, 2012
I only build on SS as I'm almost exclusively temp control, my standard build for RDL is single coil fused clapton ~0.4-0.5ohm, SS316L, 30g core wires, 38 outer wrap, I forget how many wraps (~8/9 I think) as it's been a while since I built as I still have a stockpile from last build session and some purchased ones.
For MTL I'm simple round wire SS316L 28g, 8/9 wraps 0.75ohm.
- Mar 20, 2013
Thanks. Makes sense. I wouldn't go below 0.4 too.
NZtechfreak
- Jan 19, 2012
Agreed, the sweet spot for me for single 18650 squonks, still good performance in terms of vapour and flavour, but atty stays cool enough and doesn't smash batteries too badly.
- Mar 20, 2013
That's the important bit. Clouds will happen anyway, right?
- Mar 20, 2013
My new atomizer. Vandy vape kylin. Mesh coil. Good flavour and 100-120 ml. with the same cotton. Easy to build
Almost pulling my trigger on this one. Heard good things about it!
The atomizer is inexpensive and you buy premade coil or a roll of mesh. You find the premade cotton tooAlmost pulling my trigger on this one. Heard good things about it!
- Mar 20, 2013
premade coil
Yeah, these days I wouldn't roll my own coils, I won't make something as fancy as those premade fused Claptons and alike.
this rta is easiest in every direction i think we are similar...meaning no patience for coil, cotton, etc. etc.Yeah, these days I wouldn't roll my own coils, I won't make something as fancy as those premade fused Claptons and alike.
- Mar 20, 2013
No patience at all
@paradoxper was ahead of the curve on the Mesh thing. I can't believe the difference between mesh and normal coils / SS Coils. Smooth hits, bags of flavour (even flavour) and really good saturation. I bought loads of stuff for building my own coils. I may retire them before even using them lol. It'd suck building with Raynauds anyway. Battery life sucks now and I'm going through E Juice like Air despite being a light vaper but I guess that's the trade off.
- Mar 20, 2013
When I started vaping many years ago, my first serious purchase was Kraken RTA with mesh rolled as far as I remember. I ditched this quickly and moved to Kayfun.
