Darknet
- Aug 17, 2012
Has anyone ever tested v moda's 60 day test drive guarantee? Or could clarify what it exactly does :3
You have 60 days to decide if you like the headphones or not...if you don't, no questions asked return policy. No, I haven't personally done it though, I love my M-100s
The E7 is pretty good for what you pay for, the E17 I've read is even better and worth the price difference from the E7. I don't know much about the E07K nor the E12.
Hey everyone,
I have a quick question to ask: My cousin's boyfriend owns a pair of the Crossfade LP's, and when I try them on, my ears touch the driver. (As in, they stick out far enough I guess to touch the mesh that covers the actual speaker) and this creates a relatively uncomfortable listening experience. Does the M-100 have more "Depth" to the ear pads, meaning that there's more space between my ear and the driver? 'Cause I'm almost set on buying them, but if they're going to be rubbing up against my ears the whole time, it will simpyl be too uncomfortable to buy.
Thanks in advance,
~Ty
Thanks Miceblue for those comparisons
I may have to opt maybe for an O2... If I'm walking about with it though. No idea where I would put it, haha. Wouldn't want to make it look like I have a certain something permanently!
Either that or the Android specific amp by FiiO or V-Moda
Hey guys ! I own the M100 too and i kinda have some comfort issue. I tried the paper towel method, and it hardly work. The back of my ears still hurt after used. Is there any other method? And i kinda considering getting the LP/LP2 memory cushion. How effective is it? Please give me some advice. Thanks in advance.
My M-100 finally cracked ...I was flexing it 'cos the clamping was a little too strong. Well the damage doesn't affect the sound :-
Any word on the velour pads? I feel like they would drastically reduce the bass for some reason by like 35%
Hey everyone,
Thanks in advance,
~Ty
I think V-MODA's new amp (VERSA) is going to be a device that works across all major mobile platforms (Android, iOS, Windows). But yeah if you're looking for something more portable, the O2 is not something that's easy to carry around. Amazingly enough, it fits fine in my jacket pocket but it's a hassle trying to adjust the volume knob with a bunch of cables in the way.
I think the LP/LP2 pads help with the comfort level even though they're a bit smaller in terms of the ear hole space, but it changes the sound too much to recommend using it.
Woah, that's kind of scary.
I usually flex my headband by gripping the headband itself rather than the sides where the wing plates are.
No word on the velour pads yet. I'm still interested in trying them out too since velour pads do tend to reduce the bass, depending on the density of the material of course.
From what I measured on my M-100 and LP/LP2 pads, the M-100 does have more depth in the earpads, but because it's a softer material, it compresses more than the LP/LP2 pads.
So the short answer is no there isn't more depth with the M-100. I've actually found the stiffer LP/LP2 pads to be slightly more comfortable. Earpad mods do help a bit, but the M-100 pads are still quite squishy and so they still do compress.
Quote:From what I measured on my M-100 and LP/LP2 pads, the M-100 does have more depth in the earpads, but because it's a softer material, it compresses more than the LP/LP2 pads.
Don't forget pads (memory foam/regular foam) will compress with use... How much use have your LP pads had?
Originally Posted by miceblue /img/forum/go_quote.gif
Well lookie what we have here. I tried the LP/LP2 pads again and this time it sounds MUCH better than what I recall from last time....to the extent where it sounds very similar to my original pad mod.
I must not have had the pads in all the way last time because I noticed that tucking the last part of the pad into the earcup was particularly difficult for me.
dbdynsty25, I would be interested in what you think of the M-100 with your LP/LP2 pads.
With the LP/LP2 pads correctly installed:
- bass is reduced about as much as my original paper towel mod, check
- midrange is more forward, more so than with DigitalFreak's mod, check (Lindsey Stirling's violin is forward and focused-on, check)
- treble extension/upper-treble is increased, making it more suitable for rock music, check (drummer mode is in action, check)
- soundstage is much wider and less deep, check (it passed all of my soundstage tests: Team Fortress 2 sentry surround sound, Pink Floyd's "Another Brick in the Wall, Part 2", Ottmar Lieber's Up Close album, and even passing the binaural recording effects in Pearl Jam's Binaural album)
- instrument separation is increased, check (instruments are better defined, making it a much better contender for rock tracks with a lot of notes being played at once by different instruments)
Interesting interesting. I'm really, really, really liking my LP/LP2 pads on the M-100. Earpad mods are not needed with these pads, so both comfort and sound are not a problem for me.
I'll have to give this a better listen on Wednesday. I need some sleep now. >.>
Quote:I think the LP/LP2 pads help with the comfort level even though they're a bit smaller in terms of the ear hole space, but it changes the sound too much to recommend using it.
No offense man, but this is what makes it hard for me to follow some folks on this forum and make me wonder if they are hearing things or their brains are telling them that they are hearing things....and honestly, it leads people that don't read (or remember) all of the posts to have major issues deciding what to do.
