bbmiller
- Jan 20, 2014
Hello
I have had some limited success using the parametric equalizer "Equalizer APO" to equalize a headphone, however if I could get the GUI recommended to me of PEQUI-10MC running further improvement with my headphone equalization would go quicker I believe. So could you help me please? The things I am not sure about is
1.executable file EXE available for PEQUI-10MC.
2.is this some sort of C++ runtime dependency which would require me to download what it said to be written with "Microsoft Visual C++ 2010 Express in 32-bit Windows Vista"
3. How do you achieve this ("If the path line found in peqgui10mc.ini points to the folder where config.txt of EqualizerAPO is located, it's possible to use this GUI as kind of realtime EQ.") I mean the pointing mentioned in the parentheses which is a quote from the page on PEQUI-10MC .
