jacallery
- Nov 20, 2006
Hi I am planning on going from my PC(as source) to an AD (Stello DA100)
whichh is located at my stereo in the next room. I plan on going into the wall
and up and down the wall in the stereo room. I need to use wall plates at both ends to make it look nice for the wife. The distance needed to cover to travel this way is about 30'. I know USB can only carry about 15', so would it work to go PC/USB>USB extender >CAT5/wall plate>Cat5 30' run>Wall plate/CAT5>usb extender>USB>DA100....wow that looks painful.
Or best to go PC/Optical>Optical Wall plate>30'optical cable>optical wall plate>optical cable>DA100. Sonically which is best if both can even be done.
If anyone had any better ideas I am all for it. For the USB extender I would probably use a gefen product.
thanks,
callery
thanks,
callery
