USB DAC's and USB external hard drives
Aug 3, 2010 at 6:23 PM Post #4 of 5
MCC
I've never had any issues from doing that. If you're concerned you could always clip a Radio Shack ferrite core to the end of the USB cable closest to the DAC to filter out RF interference.
Aug 4, 2010 at 12:36 PM Post #5 of 5
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
Usually not, but sometimes neighbouring usb devices can cause some interference with each other (or if a USB device has an external power supply, such as a hard drive, then that power supply might cause issues as well). If a problem exists, sometimes ferrite beads can help, or even just switching to a different usb plug.
