Growler20
- Jul 9, 2013
Ello,
I currently own the Asus Xonar U7 USB DAC, and am looking for an upgrade.
I'm currently looking at the Creative Sound Blaster E5. I would be using it for listening to music through the Sennheiser IE80 IEMs. Also, I use Tidal Hi-Fi so would be using FLAC quality tracks. Also worth mentioning, I am using a laptop (Toshiba).
My question is, would the difference be significant between the two DACs? And if you have any other suggestions, that would be great.
Thanks!
Thanks!
