USB-C to 3.5mm adapters (DAC) - Let's find the best
Mar 28, 2021 at 9:02 AM Post #2,222 of 3,926
chifihead
Indonesia
I'd just like to share the fact that Ibasso DC03 works well with my Samsung A72. That is all.
(I have a suspicion that the compatibility issue surrounding DACs and Samsung phones actually has more to do with their Exynos processor rather than the Samsung brand, but I can't prove this at all. The A72 uses a Qualcomm SOC.)
Apr 1, 2021 at 5:53 AM Post #2,223 of 3,926
chichaphile
nearby
Hello iBasso DC03 & DC04 owner 😻
dont forget to update new firmware for your iBasso DC series
https://ibasso.cn/portfolio/ibassodc0304v11
Apr 2, 2021 at 3:54 AM Post #2,225 of 3,926
sunsun89
Indonesia
hi im newb in this audio,.
i plan to buy DAC for improve my IEM (blon Bl05s)
should i buy audirect beam 2S (3.5/2,5) / audirect beam 2se/ hiby fc3? or do u have another recomendation?
it should be portable DAC plug n play with no batteries.
thx for the feedback
Apr 2, 2021 at 8:34 AM Post #2,226 of 3,926
profusion
Bulgaria
Hi all,
recently got earbuds that are 32om and using them with an iPhone the volume level is quiet or at least I have to go to max to be ok.... what you can recommend as most of the time I see USB-c types?
PS earbuds are not expensive (chi-fi openheart earbuds) so I will probably not get anything more than 15-20$? If I cannot find I will probably rise my IEMs and give away these?
Apr 3, 2021 at 3:34 AM Post #2,233 of 3,926
Ichos
Reviewer at hxosplus
Greece
For you which of the two do you prefer
To tell you the truth they sound identical.
The A30 might be a little fuller sounding but it might be placebo as well.
Not very sure and very difficult to tell them apart.
I would choose considering functionality and design.
On a side note the A30 works with some Samsung phones that the iBasso isn't.
Apr 3, 2021 at 4:21 AM Post #2,234 of 3,926
chichaphile
nearby
newest firmware of iBasso DC03 & DC04 FIXED SAMSUNG compatibility issue 💖
