Davy Wentzler
Member of Trade: eXtream Software Development / Audio Evolution
- Dec 18, 2012
Nope. Not with my rig. Doesn't work. Oh well, so close yet so far away.
Which Samsung phone do you have?
It is very likely you have enabled the parametric EQ or MorphIt without having purchased these. They stop processing after 60 seconds.
Galaxy S5Which Samsung phone do you have?
Galaxy S5
My bad. Problem solved. Perfect.Do you have 'Use volume rocker buttons' enabled in the app's Volume settings?
If you set Morphit to the same gear that you're using, why does it change the sound for the worse? Shouldn't it remain the same?
Copycat or impersonation, doneBy the way, can some of you report the app 'USB audio player' on the Play Store as inappropriate? They copied our texts, took our name and it does not do what is described.
is it trail version tends to stop halfway while playing music?
huawei mate 20 x using with powerdacv2
so is mobile problem that cant be solved?Most Huawei's are problematic with USB audio, although mid-way stopping is rare. Usually you get an error message when starting playback.
