USB Audio Recorder PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Discussion in 'Portable Source Gear' started by nztechfreak, Feb 5, 2014.
9 10 11 12 13 14 15 16 17 18
20 21 22 23 24 25 26 27 28 29
  1. peter123
    Thanks, I've got that in place.
  2. seeteeyou
    Regarding *.CUE support, I found something for Android here
    https://github.com/tguillem/android-mpd/tree/master/src/cue
    cue_playlist_plugin.c
    cue_playlist_plugin.h
    embcue_playlist_plugin.c
    embcue_playlist_plugin.h
    https://github.com/tguillem/android-mpd/tree/master/src/playlist
    Also did a quick search and got something else
    https://github.com/cmus/cmus
    https://github.com/mpdflaccuesupport
    https://github.com/vchimishuk/cue-go
    https://github.com/justlaputa/cue-parser
    https://github.com/relikd/CUE-Sheet_sublime
    https://github.com/xiph/flac/blob/master/test/cuesheet.ok
    https://github.com/smgoller/flactag/blob/master/Cuesheet.cc
    https://github.com/mewkiz/flac/blob/master/meta/cuesheet.go
    Maybe MPD could be a good place to start?
    http://git.musicpd.org/cgit/master/mpd.git
    Usually we'll find these combos when we prefer to keep metadata inside the CUE sheet itself instead of modifying the file with the audio, it's often a single file instead split tracks:
    *.CUE + *.APE
    *.CUE + *.FLAC (or *.ALAC)
    *.CUE + *.TTA
    *.CUE + *.WAV (or *.AIFF)
    *.CUE + *.WV
    For mirroring the entire redbook CD image, it's closer to ISO format like this:
    *.CUE + *.BIN
    As always it would be fantastic if Unicode support for CUE sheets could be implemented properly
    https://github.com/kuyur/unicue
    http://code.google.com/p/unicue/
  3. daniel_hokkaido
    Could you release some code which allowed the community to make their own skins Davy?
  4. daniel_hokkaido
    Sorry I guess I was not clear. A cue file allows you to rip albums as single files but play them as multiple. For example, on my macbook a folder may have a single flac file comprising a whole album but using my music programme audirvana, if there is a cue file in that folder, the programme recognises that there are in fact 9 or so songs in that single FLAC file and divides them up in its playlist. pretty handy.
  5. hypersonic
    Why every time the app launches the volume is defaulted at such a high level? First time running this app almost deafened me. I would appreciate if the default startup volume is at zero(or better, user customizable). Other than that the app is great.
    (sorry if someone else mentioned about it before)
  6. Davy Wentzler
    We will consider it.
  7. Davy Wentzler
    Now, that we can do. What I was worried about was that you wanted the .cue file to reference a .bin or .iso file, which is certainly not something we would be able to parse/read.
  8. Davy Wentzler
    The hardware volume is saved in the preferences when you change it. But if you have the option turned on to enable the hardware volume buttons, then it will take the current volume of what your Android device is set to, otherwise there would be a discrepancy between the two.
  9. hypersonic
    unfortunately, the problem persists. No matter I enabled the hardware button or using the onscreen slider, the volume jumps back to high level everytime the app is restarted. (In the mean time the usb dac stays plugged) If I use the hardware button, there is no visual indication to remind me how loud it's playing. Actually the moment I press Vol+ or Vol- immediately after starting up the app, the system volume bar will be showing the correct value(lower value),but the sound coming out is LOUD. It only resumes after any change of volume. Which means I have to remeber to adjust the volume after every startup. Luckily I don't have any heart issues. Not the end of the world though. I still like this app and of course bought the paid version already. Any clue why it's happening?
    Phone: Moto X 2013, stock 4.4.4
    DAC: Resonessence Labs Herus+
  10. Percival
    Must be your DAC. Doesn't happen with mine (Cambridge Audio DacMagic XS).
  11. hypersonic
    ok, the problem solves itself.
    weirdly, It's not happening anymore.
    But I do can observe, even when nothing is plugged(no dac, no headphone), the volume slider does jump back to a certain level at each startup. Davy is it a normal behaviour?
  12. Davy Wentzler
    Thanks, we have found a library. Note that we cannot use GPL libraries, such as mpd.
  13. hypersonic
    UPDATE:
    It's fine now. probably I did not stop playback before changing the option. My bad. Next time I shall do more trials before posting. I'm sorry Davy.
    Davy, from 1.5.1 hardware volume control doesn't work with my dac anymore. i.e. the slider does nothing, instead the physical button works('use volume button' option is NOT enabled, so it shouldn't be happening)
    that means the volume is now limited to a very low level. It was working perfectly in 1.5.0. Are you noticing this problem yet?
  14. Davy Wentzler
    No problem. I just tested with 3 DAC's and they all controlled the volume just fine.
  15. GloryUprising
    UPnP Support - Render and Control Point!
