USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
May 17, 2018 at 12:59 AM Post #1,578 of 6,145
May 17, 2018 at 9:55 AM Post #1,582 of 6,145
Nope. It still sounds bad. I have tried to uninstall and install it back (after running a cleanup program). It still cached settings I think. How to clear settings for UAPP? To get default settings.
Uninstalling should be enough. But I doubt it is your settings though. Can you please contact support at info@extreamsd.com, since this is not our support forum?
May 22, 2018 at 5:36 PM Post #1,583 of 6,145
I've been using uapp for about 2 months on a lg v20. So far so good except for some glitches when using tidal and internet connection is poor, sometimes i have to restart it but i can live with it.
Maybe people already asked about it, are there any plans to support offline tidal tracks? That would be a major hit and accomplishment.
May 22, 2018 at 10:02 PM Post #1,584 of 6,145
It"s not that. Davy, the developer was asking Tidal a lot of times for such. Tidal won't allow it.
May 30, 2018 at 3:30 PM Post #1,586 of 6,145
how to set usb audio with fiio x5iii, to get best playback without bit loss
Jun 1, 2018 at 12:20 AM Post #1,587 of 6,145
For any FiiO X5III owners with the Meridian Explorer2 (ME2) DAC trying to use their X5 to stream Tidal with UAPP (v4.3.1): The latest X5III 1.21 firmware (which specifically claimed to enable USB Audio) for the X5 is now enabling me to smoothly stream Tidal Masters (MQA) and HiFi.
In previous X5 firmwares I had an issue where I got dropouts/DAC lights flickering while streaming. Now it's smooth sailing and I can stream and render Masters files in Tidal (blue lights, green lights, etc.) without any hiccups. Ditto for regular HiFI.
Note: In my case I had to go into UAPP USB tweak settings and click tweak #2 as I was getting errors and stuff wouldn't play sometimes. I'm not 100% sure that the tweak fixed it (could have been some other reason like getting other streaming glitches, etc. that were randomly happening self-resolved) but I've left it in place along with selecting bit perfect for the DAC. I'm really enjoying the results.
I have my X5 also stacked with a Cayin C5 portable amp (for extra power, bass boost option and a little easier to control the volume). Total stack is X5, C5 and ME2. A real handful!
The combo of the X5, C5 and ME2 is a smooth, sweet sound and, especially with MQA files (I stream a lot of the more recent ECM Masters stuff), a real silent background and very clean crisp highs and deep lows. I still get the occasional decoding error that stops playback but they're infrequent. In those cases I just go backwards and select another song or retry the previous one and it plays fine.
Update: I think these decoding errors are due to crappy WiFi connectivity when far from my router. As said, one of the The X5III's issues is its weak WiFi, especially if your router might be older and less advanced/robust. When closer to the router the playback is way more consistent.
Jun 1, 2018 at 7:09 AM Post #1,588 of 6,145
I am inclined to agree with many critics that MQA is a bit of a con:
https://darko.audio/2017/03/highresaudio-com-calls-for-a-deeper-technical-analysis-of-mqa/
http://www.realhd-audio.com/?p=6109
https://www.computeraudiophile.com/forums/topic/30381-mqa-is-vaporware/?page=306
https://www.reddit.com/r/audiophile/comments/5tvg5k/mqa_is_bad_for_music_heres_why/
https://benchmarkmedia.com/blogs/application_notes/163302855-is-mqa-doa
https://www.soundstagehifi.com/index.php/opinion/954-myriad-questions-about-mqa
Jun 1, 2018 at 9:57 AM Post #1,589 of 6,145
@BobSmith8901
Try set to "Original Android Driver" under Settings/Internal Audio Driver menu if it does the trick. When using USB DAC.
