USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Oct 22, 2020 at 10:08 PM Post #4,172 of 6,156
That makes logical sense.
Where is the menu option to scan the whole card? Other players have that. Where is it here?
I've gone into Library, and when you select the three vertical dots, there is an option for scan. But it doesn't look like it's doing anything when select that option.
And always, always, when i go into a folder, it is spending 5 seconds "adding" all the songs in the folder, before actually playing a song.
It's been awhile since I inserted a new card so tonight I did and here's how I scanned it: opened UAPP, clicked on Library, then clicked on the upper right 3 vertical dots and selected scan, then automatic. Once it finishes scanning you should be able to see all your folders and albums.
Oct 22, 2020 at 11:00 PM Post #4,174 of 6,156
When streaming Tidal with this app sometimes pressing back button skips the current track, the box is not toggled in the setting. Does this happen to anyone here and is there a fix?
Oct 23, 2020 at 9:10 AM Post #4,176 of 6,156
I'm getting a non MQA DAC (Sonata HD Pro) and will stream from TIDAL.
Will USB audio player pro undlock MQA so I can listen to TIDAL with the Sonata?
Yep! First unfold up to 24-bit/96kHz.
Oct 23, 2020 at 10:34 AM Post #4,178 of 6,156
Just make sure you get the MQA software add-on, which is an in-app purchase in UAPP.
Those who have DACs with hardware MQA decoding and rendering do NOT need this add-on.
Oct 23, 2020 at 3:31 PM Post #4,179 of 6,156
Is there a way to rename UAPP Server?
Oct 24, 2020 at 9:29 AM Post #4,180 of 6,156
APE file support :deadhorse:
Oct 24, 2020 at 11:08 AM Post #4,181 of 6,156
So happens I'm playing it just now... :L3000:
Oct 25, 2020 at 2:37 AM Post #4,183 of 6,156
Hello,
perhaps someone can help me)
i use Huawei p40 Pro phone with Dragonfly Cobalt and need to get USB Audio Pleyer Pro - is there a way to purchase in directly from developer because i dont have playstore(
i did purchase the app via playstore via my other android phone and then have sent it to P40 via phoneclone app , but it dosent work(... crashing from the start
Thank you
best regards
Alex
Oct 25, 2020 at 2:58 AM Post #4,184 of 6,156
Try installing APK Extractor on your other phone. Extract UAPP and sideload it to your Huawei phone.
