USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
post-15599871
Post #3,796 of 4,275
dfairchild
On devices with a MQA decoder and MQA renderer built-in, like the V30, UAPP uses these and you get the two MQA unfolds to 176.4/192.Khz. When you buy and use the MQA decoder in UAPP, it can only do the first MQA unfold to 88.2 or 96kHz, since there is no MQA renderer inside the app. An MQA renderer would also need to be different for every DAC used. The first MQA unfold however, is the most important one.
@Davy Wentzler
Hi Davy,
I recently installed UAPP on my venerable LG V30 and it's working and sounding great. I am a Tidal HiFi subscriber, and was just wondering about MQA unfolding via UAPP. "The 2L The Nordic Sound" MQA album on Tidal seem to be a super high 352.8 khz 24 bit album, but UAPP seems to be unfolding it at 176.4 khz under the "direct" setting. It sounds wonderful, and I doubt I could ever hear a difference, but just curious if the 176.4 khz lower number is a function of the DAC chip in the phone or UAPP, or both. Appreciate any insight you can share here, and thanks for the fantastic app.
@Davy Wentzler
Hi Davy,
post-15600551
Post #3,797 of 4,275
Dmitry89
Russia
Russia
Installed UAPP on the M11Pro device. All good. I listen to Tidal. I have a question. Why does UAPP not fully decode MQA files?
post-15601182
Post #3,799 of 4,275
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
How do i remove "The" from band names from my library.
I think the Library is populated by reading the Tags in the music files. You may have to use a tagging program on your PC, to modify either the Artist, Album Artist, or Track Artist tags in the files you're concerned with.
post-15601406
Post #3,800 of 4,275
HaBo
France
France
SMSL IQ (dac) + Windows (laptop) + Jh Audio Layla , all at max volume = insane loud
SMSL IQ (dac) + UAPP (smartphone) + Jh Audio Layla, all at max volume = loud but not painful
Why ?
post-15601484
Post #3,802 of 4,275
m-i-c-k-e-y
The Eternal City
The Eternal City
true... true...
post-15602769
Post #3,804 of 4,275
Chikolad
So on my LG V20 changing the volume through the physical buttons doesn't work when the app is in the background or when the screen is off.
I have the "use volume rocker buttons" setting checked.
Is there anything I can do to solve this?
post-15603524
Post #3,805 of 4,275
Dannemand
FL, USA
FL, USA
Try disabling that checkbox, leaving it to the phone to adjust AVC volume when pressing the volume buttons. Works for me on V30.
post-15603996
Post #3,806 of 4,275
ShaneS2992
Hey everyone,
I'm new her so if there is a thread that this is better suited for please let me know. I see the 24/32 bit part of the title but can't find a thread as close as this one is to what i need that is down at 16bit...
Anyway, I am using the xdp-300r and my question is how do I check if uapp is being resampled by android? I'm running 44.1kHz 16bit aiff files as I've recently ripped a ton of cd's and didnt want any degredation of the rips due to upsampling on import.
My next issue is making sure the tracks don't get upsampled by Android during playback in UAPP.
I was able to see the output sample rate/bit depth in the stock player as well as in a sub menu of Poweramp which let me know it was being upsampled by android but I can't find an area of the sort for UAPP ...
Any and all help would be greatly appreciated!
post-15604691
Post #3,807 of 4,275
almarti
Spain
Spain
It is clear for me, at least using HiBy R5 player, than UAPP playing Tidal is much better than Tidal in both direct 3.5mm headphone output and paired with Chord Mojo.
So, is there an UAPP brother for MacOS or Windows 10? I have listened opinions about Roon and Amarral but I am not sure if they will improve Tidal on MacOS/W10 (I have both platforms).
Thanks for your comments
Reactions: buonassi
post-15605191
Post #3,808 of 4,275
Chikolad
Nope, doesn't work with the checkbox unchecked either :frowning2:
post-15606191
Post #3,810 of 4,275
zolom
Here
Here
Using the UAPP, playing bit-perfect Tidal HiFi via the Chord Mojo (as well as non-bit-perfect via BT ES100).
Recently I stumbled across the Chord Poly (support hirez DLNA over wifi 2.4Mhz).
1. Can it be used via the UAPP?
2. If not, is it planned?
3. Is there a need for a 3rd party UNPP/DLNA app?
Please advice.
Thanks.
