USB Audio -> HeadAmp
Jun 13, 2003 at 3:20 AM Thread Starter Post #1 of 8
tonyjang
Does anyone use a setup similar to this:
PC USB -> Xitel USB -> Analog -> Headphone Amp -> Headphone?
This seems like a good way to get clean sound from the computer/laptop.
Jun 13, 2003 at 3:46 AM Post #2 of 8
Other better USB options are M-Audio Sonica and M-Audio Audiophile 24/96 USB. A cardbus solution for laptop is the Echo Mia. All are 24bit / 96khz capable. The Mia doesn't have digital output where as the Sonica has optical and the AP24/96 USB has coax.
The best option is to use external DAC w/ Sonica or AP24/96 USB I believe.
Jun 13, 2003 at 4:07 AM Post #3 of 8
I'm using my laptop's USB > mAudio Sonica > Corda HA-1 > Senn HD580s. Music files are mp3s (Lame a p extreme) played with foobar2000.
I haven't done a formal comparison with other sources and don't have a high end source anyway. As I recall there is a very slight loss of detail compared to a decent PCDP as a source (could be either the mp3s or the DAC in the Sonica), but the PC-based source is dead quiet compared to the PCDPs I've heard. I don't have any experience with real high-end systems, but it sounds pretty good to me.
A number of people have indicated this or a similar setup can be improved by feeding an optical output from the USB soundcard to a high quality external DAC. I don't have one, but it makes sense to me.
Jun 13, 2003 at 4:16 AM Post #4 of 8
Do a search -- there are many, many threads about this. To sum them up, the Xitel USB units have a fairly poor analog sound quality (in particular, virtually no bass below 50-60 Hz). Better analog USB solutions include the Stereo-Link 1200, M-Audio Sonica, and M-Audio USB Audiophile. In general, the M-Audio Sonica is probably the price/performance leader, with the USB Audiophile in second place.
If you're really hardcare about USB sound, you could build something like this:
http://www4.head-fi.org/forums/showt...threadid=35882
Realistically, though, you'll probably be happy with a Sonica.
Jun 13, 2003 at 4:18 AM Post #5 of 8
I have to agree with those *number of people* out there. Don't overlook the DAC. Even the humble mp3 can sound pretty darn good depends on the DAC/digital cable you are using.
I went through a DAC search for my mac set up last year and I was amased at what a difference it can make on bits-missing mp3 files.
Whether optical is depends on the system. i've tried both and ended up with a coax.
Jun 13, 2003 at 4:23 AM Post #6 of 8
I do (see sig). The Sonica wasn't available at the time. If I was shopping now I'd go the M-Audio route, though if the Xitel 25 ft cord is taken into account (I use it with my stereo) the price comparison is a little different depending on how much value you give to it (say about a third of the price).
Jun 13, 2003 at 4:57 AM Post #7 of 8
i use alt.preset.standard -> sony vaio grx560 -> sonica theatre -> 24v meta42 8620 -> headphones
good stuff in my opinion.
Jun 13, 2003 at 8:44 AM Post #8 of 8
I have been known to occasionally...
Sony Vaio -> M-Audio Sonica -> digital out -> MSB Link DAC III -> RKV -> whatever headphone I happen to be listening to at the mo'.
