URGENT HELP
May 28, 2013 at 8:31 PM Post #16 of 18
WNBC
WA
Every once in a while I run into a passive preamp but never pull the trigger.  Might not be a bad idea for some uses such as active speakers.
Originally Posted by Steve Eddy /img/forum/go_quote.gif
The problem is that it's still common to find preamps with upwards of 20dB of gain, which is absolutely ludicrous given that most power amps have input sensitivities of just a volt or two.
se
May 28, 2013 at 10:04 PM Post #17 of 18
Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
Ultimately it would depends on the length of your cable runs. Resistive-based passives have relatively high output impedances (for example, 2.5k for those based on a 10k potentiometer) so cable capacitance can be a bit problematic for long cable runs, rolling off the high frequencies.
se
May 28, 2013 at 11:24 PM Post #18 of 18
Fukuoka, Japan
I'm also wondering if this is a good deal? If they happen to not work we can get store credit which is fine.
If they don't work, you should get a refund
