The FH5s has entered the market for about 4 months, which has been warmly welcomed among consumers. Apart from its unit configurations, you may be most attracted by the cable with interchangeable headphone plugs. Based on strong suggestions from many of our users, we carefully upgraded the cable. This means that other than the original FH5s, another higher-end FH5s Pro with more playabilities is coming to you.
The original and the pro version have basically the same configurations- dual dynamic driver+dual balanced armature. The main difference is the using material of each included cable.
FH5s standard version cable:
The original cable included in the FH5s is made of monocrystalline silver-plated copper in Litz Type 2 style to faithfully reproduce your music. In addition, the cable features interchange audio plugs of 2.5/3.5/4.4mm with expanded MMCX connectors, leading to a more amazing music experience.
Aug 27, 2021 at 3:42 PM
Post #2 of 21
FH5s Pro exclusive cable, LC-RC
The LC-RC is made of high-purity monocrystalline silver-plated copper, with 8 strands of 19 wires each for a total of 152 wires. Braided together in Litz Type 2 style, each wire is individually insulated to effectively improve transmission efficiency for high frequencies as well as ensure high resolution. In terms of the housing material, the LC-RC uses
transparent environmentally friendly TPU (Thermoplastic polyurethane) from Germany, greatly protecting the cable from being colored after a long time using and from turning solid under low temperatures. Likewise, the LC-RC also features 2.5/3.5/4.4mm interchange audio plugs.
The FH5s is available here at our AliExpress Official Store:
https://www.aliexpress.com/item/1005002547825019.html
The FH5s Pro is available here at our AliExpress Official Store:
https://www.aliexpress.com/item/1005003176683587.html
Here, we are also preparing a surprise for our users with the exclusive cable of the FH5s Pro, LC-RC. That is, a 30% off discount, so you can separately take the cable by paying just 49.99 USD, which is officially priced at 69.99 USD.
* This promotion activity will be carrying on from Aug. 28 to Sept. 13, 2021 (PST).
* Each ID can only get one discount coupon for 20 USD.
* This discount is only available at our AliExpress Official Store.
* Click the link here for a quick takeaway of the LC-RC cable:
https://www.aliexpress.com/item/1005003200318777.html
Notes:
If you are an owner of the FH5s and have an idea to upgrade it to the FH5s Pro by taking an LC-RC cable, but missed the promotion activity, please send an email to support@fiio.com attached with the 20-digit security code of your FH5s (the one printed on the package box). We will get to you once we receive your message.
Best regards,
Guangzhou FiiO Electronics Technology CO., LTD.
asifur
The LC-RC is made of high-purity monocrystalline silver-plated copper, with 8 strands of 19 wires each for a total of 152 wires. Braided together in Litz Type 2 style, each wire is individually insulated to effectively improve transmission efficiency for high frequencies as well as ensure high resolution. In terms of the housing material, the LC-RC usestransparent environmentally friendly TPU (Thermoplastic polyurethane) from Germany, greatly protecting the cable from being colored after a long time using and from turning solid under low temperatures. Likewise, the LC-RC also features 2.5/3.5/4.4mm interchange audio plugs.
Notes:did not like the FH5S the BA hits right into the ears making the treble very peaky. I hope FH5S Pro does better. Otherwise, not recommended.
Best regards,
Guangzhou FiiO Electronics Technology CO., LTD.Aug 27, 2021 at 3:50 PM Post #3 of 21 Dsnuts
- Jun 20, 2011
This new LC-RC cable is the same cable that was included for the FD3 pros. It is made of a higher purity copper it looks like which does have a positive effect for the host earphone. The sound gets a natural expansion of stage and depth. Its texture is enhanced using this cable. It is showing some enhanced copper properties more so than the silver properties of their previous cable that was included with the FH5s. Which is a good thing. I will have much more to say about this cable here in a shorter review describing the differences from their stock cable to the new Pro LC-RC cable.
The new cable is worth getting imo. It is clearly a better cable and I think it matches better with the FH5s and enhances their sound as well.Aug 27, 2021 at 8:12 PM Post #4 of 21 sabloke
I ordered the LC-RC cable yesterday. Price so good and replaceable plugs made it irresistible. Hope it will go well with my Sony IER-Z1R.This new LC-RC cable is the same cable that was included for the FD3 pros. It is made of a higher purity copper it looks like which does have a positive effect for the host earphone. The sound gets a natural expansion of stage and depth. Its texture is enhanced using this cable. It is showing some enhanced copper properties more so than the silver properties of their previous cable that was included with the FH5s. Which is a good thing. I will have much more to say about this cable here in a shorter review describing the differences from their stock cable to the new Pro LC-RC cable.
The new cable is worth getting imo. It is clearly a better cable and I think it matches better with the FH5s and enhances their sound as well.Aug 28, 2021 at 2:58 AM Post #5 of 21 LC-RC cable is already out of stock...Aug 28, 2021 at 3:01 AM Post #6 of 21 yiuyiu
- Aug 3, 2012
wow... I have it in my shopping cart, but can't check out..Aug 28, 2021 at 3:03 AM Post #7 of 21 Had it in my cart as well, along with another item. Refreshed it and then the cable was gone. Went back to check and the cable was updated to ‘temporarily out of stock’wow... I have it in my shopping cart, but can't check out..Aug 28, 2021 at 4:04 AM Post #8 of 21 Hanesu
I honestly think it is cool that Fiio is one of the few companies that truely listen to their customersAug 28, 2021 at 4:26 AM Post #9 of 21 ledzep
Looks like my prays were answeredThis new LC-RC cable is the same cable that was included for the FD3 pros. It is made of a higher purity copper it looks like which does have a positive effect for the host earphone. The sound gets a natural expansion of stage and depth. Its texture is enhanced using this cable. It is showing some enhanced copper properties more so than the silver properties of their previous cable that was included with the FH5s. Which is a good thing. I will have much more to say about this cable here in a shorter review describing the differences from their stock cable to the new Pro LC-RC cable.
The new cable is worth getting imo. It is clearly a better cable and I think it matches better with the FH5s and enhances their sound as well.Aug 28, 2021 at 12:10 PM Post #10 of 21 Dsnuts
- Jun 20, 2011
Ya I am writing about what this cable does and it doesn't enhance treble notes as much as their prior included cables. This in turn makes the FH5s now listenable for rock and metal. It sounds way more cohesive using this cable. These are what they should have included with their FH5s. It is a substantial cable and upgrades the FH5s to a different level. It improves cohesion and even improves the mids and bass end to have greater note weight with a more expansive stage to boot. Their FH5s pro sees a clear upgrade for its tuning due to this cable. I will have much more to say on my review of the LC-RC/ FH5s Pro soon.Aug 28, 2021 at 2:21 PM Post #11 of 21 bachankas
- Jan 30, 2013
Will the LC-RC be available in 2-pin version in the future?Aug 28, 2021 at 8:58 PM Post #12 of 21 Dsnuts
- Jun 20, 2011
https://www.head-fi.org/showcase/fiio-fh5s-pro.25384/reviews#review-26640
Fiio FH5 pro. These cables improve everything about the FH5s including the treble.Aug 29, 2021 at 11:22 PM Post #13 of 21 yiuyiu
- Aug 3, 2012
The cable finally back in stock for purchase. Nice...Aug 30, 2021 at 4:19 AM Post #14 of 21 ledzep
Thanks for the update, just grabbed a coupleThe cable finally back in stock for purchase. Nice...Aug 30, 2021 at 11:47 PM Post #15 of 21 Dear friend,Will the LC-RC be available in 2-pin version in the future?
Thanks for your interest in the LC-RC. We do not have plan for the 2-pin version currently.
Best regards
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
