EasyEnemy
- Dec 9, 2016
I updated to V1.2 a while back.
I don't know what you can try next. So sorry I couldn't be of any help.
A YouTube video says signal clips on both headphone jack and line out port if the volume hits 100% and it’s because of the hardware. I assume the PSU couldn’t supply enough power at 100% volume.Im not sure about the non gapless feature as the first half second of each song is cut anyways. So its essentially useless to have gapless. However if there is a blank half second in front of each song its almost gapless.
Now concerning output. The X10 has line out that works perfectly fine. Owning an X3, i know the line out clips at max volume but i suspect that is because of rockbox.
Yup. The IEMs mentioned were my JH Audio's Michelle. I sold my Michelle earlier this month.Sensitive iems usually refer to pairs with less than 16 ohms impedance and/or above 115db/mw sensitivity
Yup. IMHO Xduoo DAPs excel in great measurements. Both X3 and X10 on the papers are very great sources, low distortion regardless of load impedance, low noise floor, low output impedance. But they always have flaws that resulted from their carelessness e.g. X3’s playback and pitch error and clipping issue, X10’s playback error, UI glitchesThe X10 may have slightly better specs on paper for the DAC but its sound is much better than the X3 due to a higher quality op-amp.
The X10 reportedly has even less output impedance compared to the X5 3rd gen.
Personally i would put the X10 a step above the Fiio X5 3rd gen in terms of sound.
My only gripe with the X10 is the lack of an equaliser
I suspect that it may not do gapless , the regular X10 does not. The X10T is basicly an X10 with out an internal dac.Anyone here have the X10T transport? Trying to find out ifr it supports gapless playback of FLAC through the coax or AES outs??
Would love a review!
